Question about D-Link AirPlus DI-524 Wireless Router
I cant connect wirelessly but if i put the cable in i can connect
When i try to see why it says my computer has found wireless things to connect to but its not configured.
I also called customer care and i was told that i deleted what i needed to connect to other networks
Is there a way to Download this again or is there a way for me to configure my networks, please help me
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Does your wifi work? if not then u may need a driver (that is if your computer has a wifi card to begin with)
Posted on Jun 14, 2009
  • 331 Answers
Not true. can you see your wireless router?
also can you connect from a network cable. we will have to reconfigure the router as to allow you to connect
I cant get this sylvania 7 smartbook , model # synet07wicv to get internet.
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 25, 2011 | Sylvania G-Netbook
I cant connect to internet but i installed the necessary driver
To connect to the Internet you need a few extra things aswell as a network card.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
May 18, 2011 | IBM ThinkPad X41 Tablet PC
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
Cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Wireless won't connect to the internet when in WPA TPIP mode
I have found that some routers do not like text and numbers mixed in the password. After having a ton of problems I set up the wireless password to all numbers and haven't had a problem since.
Prior to that the wireless would work for a day or so and then quit. It was frustrating.
Also, when the router calls for text or hexadecimal I have found that they really don't mean text unless it is between A to F, which isn't really text but a hexadecimal number.
So, take the simple approach. Put in all 5's for your password. You can change it later if everything works, but use all 5's just to see if you can get going.
Don't read this part if you already know this.... You have to connect a computer via a hardwire ethernet cable to the router to set the password encryption. I used 192.168.200.1 as the IP address to get to the modem. Put the IP address in your browser address bar and you should come up with a screen that is addressing the modem. Select wireless security or some similar sounding menu item and then make your selections.
After you do this, and before you disconnect the ethernet cable, try to get on to the internet using the hard wired ethernet cable. That will be bypassing the wireless routines. If you can't get on via the ethernet cable direct connection, it is unlikely that you will be able to make the wireless work because there is a problem downstream from your computer -- the modem or perhaps the connection at the street.
Once done you can remove the ethernet cable from your computer. Go to NETWORK CONNECTIONS and properties and set the identical parameters WPA, etc in the properties including the all 5's password.
If you have set the wireless to connect automatically it should connect to the internet.
good luck
May 10, 2009 | Edimax PRI-682 Router (PRI682)
Wireless internet connection not found
i need driver for my laptop by name vostro 1500 ( minicard 1390
May 01, 2009 | Gateway Computers & Internet
I cant connect to wireless on my brand new laptop :(
you need to make sure that your laptop has a wireless card in it and if it's working properly. if it has a wireless card already, the wireless card should automatically detect your wireless router (the wireless icon is usually located at the bottom right hand corner of your screen) and you just need to connect using the correct wireless settings (ssid and wireless security).you need to also check if the wireless capability of the router is enabled. make sure to check if the wireless light on the router is on.
here are the steps on how to check the wireless settings of the router
- open a web browser using a computer connected to the router via cable. enter http://192.168.1.1 on the address bar.
- it will prompt you to enter a username and password, use "admin"
- it will now promt you with your router's screen, go to the wireless section
- check the wireless settings like the wireless name/ssid that are listed there since that would be settings that you need to use on your laptop (note: you can change the wireless name/ssid to something that you can remember easily and just saev the settings)
- check also the wireless security if it's enabled
hope this'll help you
ciao!
Aug 28, 2008 | Gateway Wireless-B Router (wbr-100)
Wireless connection problem
Hello There, are there any wireless computers that detects your router? If there is, most of the laptop computers has a built-in on/off (toggle) switch on the side to enable or disable the wireless card on your computer. Make sure it is "ON" then check if it will detect the wireless connection.
If it is a desktop, try to reboot the computer then check again. If none of the computers can detect your router, make sure that the wireless light on the router is lit up. You may also try changing the channel on the router.
Aug 03, 2008 | Airlink Computers & Internet
Wireless router
First make sure wireless is turned ON or enabled on the computer, then use the View Available Networks to connect to the your SSID or network name. IF you can connect to router then you should be able to surf Internet.
Jun 26, 2008 | NetGear WGR614/WG511 (wgr614nawg511nakit)...
Want to use wireless without running cables
Did you load the DLink software onto your computer?If so you have to configure the DLink control Panel to recognize the Internal wireless card in the computer.You may also need to take the wireless card out and restart your computer,then shut it back down and reinstall the card so the computer can recognize the card and reinstall the drivers.If it cant find suitable drivers it wont install.While you have the card out look at the brand and version number and try to download software to desktop to install in case windows cant find any.If you have a cat5 (ethernet) cable you can go hard wired till you get the wireless working.
Apr 22, 2008 | Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
142 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
