Question about Pioneer GM-7200M Car Audio Amplifier
Is it good
I have 2 800watt 12inch/30cm  IMPP subwoofer/HP grave IMPP are these good speakers to have. and can i get a lot of bass out of them.  i like loud deep bass
  • 328 Answers
If you are using a GM-7200 amp, it should sound great. Both the amp and the subs are rated at 800 watts so be careful not to overload the bass by turning them on full power. It is good practice to have a slightly lower watt amp than the subwoofers. If you can power your rear speakers from the amp, that would take away some power to prevent the subs from overloading. Overall, you should get a nice THUMP!!
Posted on Oct 30, 2007
I am looking for 12"inch old styles IMPP with
best bet would be to check out an overstock speaker warehouse on web you ought to be able to find em at good price maybe check a discount warehouse also hope i was some help i also like those subs
Feb 22, 2013 | Car Audio & Video
Speaker is bad; recommended replacement speaker; it is a 30cm (12 inch)X 1
buy only one speaker of the same brand or they don´t sound well
Feb 05, 2011 | Pioneer SW100 Subwoofer
I have a proton satria 2007 model with a fully intergarted head u
First off, change the front speakers with a decent pair of aftermarket. Buy a powered subwoofer. One that has the amp built in. Connect it to the rear speakers. Bazooka tubes are great, compact, great bass.Adjust your radio so that the front speakers do not recieve alot of bass,you want it about half way. That way you are using all the power to push high notes, Bass takes a lot of power to push, reducing the volume. Turn the subwoofer to the maximum setting, and then adjust the system to your liking. It will take some time, but it is worth it in the end. Tip: set it while listening to your favorite station. Stations broadcast at different sound levels. Some pump up the bass, some don't.
Apr 15, 2010 | Car Audio & Video
Pioneer 12'' impp
It could be that the sub is underpowered or that there is something wrong with the voice coil.
Jan 19, 2010 | Car Audio & Video
Have 2 blown square hifonics 12inch speakers. Was playing goos and then just stopped. Took to radio shop and they said I have 2 blown sub-woofers. How can i get them fixed.
They probably will have to be reconed. Slight chance the flex leads have broken in which they MIGHT be repairable. If this occurred during playing very loud, you probably burned up the voice coils.
Have them reconed and then use an amplifier that maxes out at MUCH less power to drive them. Also fuse the speakers to protect them.
Dec 04, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
Need dimensions for 12' 450watt IMPP Subwoolfers for proper air space
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 200mm, depending on the frequency of bass you require.
On a 12 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
Oct 14, 2009 | Car Audio & Video
Pioneer 4 way ts a6970 what are their wattage
  • 330W MAX.
  • 6" x 9" (16 x 24cm) woofer / 66mm cone midrange / 18mm dome tweeter
  • IMPP composite cone woofer
  • Butyl rubber sound for smoother response
  • Glass-imide voice coil bobbin for higher power handling capabilities
Oct 06, 2009 | Pioneer TS-A6970E Car Speaker
Pioneer GM-7200M Car Audio Amplifier Logo
139 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
