Question about Whirlpool Calypso GVW9959K Top Load Washer
I have a CA error code, what part should be changed and how would I go about changing it out?
  • 530 Answers
Ca i believe means that you have an overcurrent problem with your motor control board. you either can have a blown fuse on the motor board or your ujoint is seizing up causeing it to think so. take to consol off and look at the board to the (if you where to be faceing the washer it would be the board to the left, if you where to be standing behind the washer it would be to the right.) So find the fuse on that board and check continuity you more than likley need that motor board. let me know if you have any more questions
Posted on Jun 14, 2009
Holdem zynga poker
No one here can 'open' a locked out account but there is support available from Zynga and even a page regarding CA codes: https://support.zynga.com/article/zynga-poker/CA-Error-Codes-en_US-1382482351703
Mar 10, 2014 | Zynga Texas HoldEm Poker
Erreur E 161 403 E
The error code in the problem statement indicates that the printhead has failed due to overheating. When this occurs, the printer "remembers" the condition, and will not operate until the printhead has been replaced by a technician who knows the service codes to reset the error condition and inform the printer that it has a new printhead.
Mar 04, 2014 | Canon iPF700 InkJet Printer
Message resent! Please verify your account by carefully following the instructions in the email. Message Code: CA3
hello Zynga poker as you see error ca:3 and its say change my fb pass an if i change pass its not working all you know its now work see massage
Mar 22, 2013 | Zynga Texas HoldEm Poker
CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error F 2 (Blinking mode) appears in Display of Sharp AR5316,
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Whirlpool Calypso GVW9959K Top Load Washer Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal De
