Question about Nokia N96 Smartphone
RM-472\RM472_002_000_M030.fpsx hiiiiiiiiiiiiiiii
Asus 2eyb6ard
HIIIIIIIIIIIIIIII
Oct 25, 2013 | Computers & Internet
Tec b-472 gap sensor
use detection transmissve in the driver
Aug 13, 2012 | Toshiba TEC B-472 Thermal Label Printer
Flashing a dead nokia n97
Hi according to my experience your problem seems to the wrong selection of flash file.So, try to download it from here n97 or if this link doesn't works please use what you have download previously .There are many flash files with a higher version.Make sure that you should select the file of your correct phone type (RM-505 or 507).....Download the flash file what it is written on your phone.After you have done this please repeat the steps.Good luck
Jun 20, 2012 | Nokia Cell Phones
N96 startup problem
Just flash the phone by using this trick Click here1.Me myself as a mobile technician I have solved this kind of problem by doing this.For you flash file,there are three types of N 96 so follow this link and choose it which is written at the back panel inside the battery (RM-297 or 247 or 472). ALL Nokia Flash Files,flash files download site,Free Nokia Flash Files,latest nokia flash file free,phone Flash Files,mobile flash files,nokia firmware,free all nokia flash files,Blackberry Flash Files,iTablet Flash Files,JAFMain Software.If you could not follow this please leave a comment or testimonial.Good luck
Mar 07, 2012 | Nokia N96 Smartphone
Hiiiiiiiiiiiiiiii
What is the problem with your phone?
Mar 07, 2011 | Sony Ericsson G900 Smartphone
How can i change my language on n97 from chinese to english?
1) Check your version on your phone by pressing *#0000#
You will see your current softwareversion (currently probably 10.something and that's why you are on this page). The model probably is N97 and the type RM-507.
It is also important you have already installed the PC suite.
2) download the new firmware via Navifirm
Run it (start-up takes a while, it retrieves data from the internet) and select the version that you want to download. Make sure that you know which firmware you want to download.
A list of all the product codes (and the ones which are already updated can be obtained here)
3) Store the files that you have downloaded in following folder:
C:\Program Files\Nokia\Phoenix\Products\RM-507
where RM-507 is equal to the code that you retrieved in step 1
You now have possession of the part that you need to upload to your phone!
To be able to flash this on your phone you need toinstall and get J(ust) A(nother) F(lasher) working
Download JAF version 1.92.62 here, and in order to get it working download OMG JAF PKEY Emulator v5: here
version 1.92.62 does not know the N97, so 1.92.64 can be downloaded. You don't need the .exe file just the .ini files. So download JAF version 1.92.64 here and only put the .ini files in the directory where you installed version 1.92.62
When this is done, open OMG *** PKEY Emulator v5. After pressing go without changing any setting you should get JAF running.
You first get an error message that Box drivers are not installed. This is OK as you don't have a box. If you get a query regarding installing new drivers keep the ones you currently have (those you got when installing the OVI suite and they are perfect)
Press BB5, now we need to tell the programm where to get the new flash files.
First select: dead USB (even if your phone is still working)
Manual flash , factory set and normal mode.
If your phone is still working you can press .ini when it's connected. It will automatically know where your You can do this by connecting your phone and press: use ini, or when it's dead press the buttons MCU , PPM,CNT and APE one by one.
You should point them to your directory
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM-507_11.2.021_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM-507_11.2.021_prd.rofs2.V28 (SWAP the file from RM-505_11.0.021_prd.rofs2.V26 and rename it to RM-507_11.2.021_prd.rofs2.V28)
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM-507_11.2.021_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-507\RM505_507_11.0.021_uda9_001.uda.fpsx
Also make sure you click the option: Change also product code and uncheck CRT 308.
Now make sure your phone is switched off and battery is in! Now take out the part that goes into your phone untill the program tells you to switch on your phone after you pressed FLASH.
Jan 22, 2011 | Nokia N97 Cell Phone
Unlocking Orange Nokia 6500 S1 (slide)
#pw+033 123 365 133 327+1# #pw+732 200 664 024 707+2# #pw+134 204 764 204 101+3# #pw+439 967 667 701 563+4# #pw+044 563 371 217 162+5# #pw+496 317 125 455 711+6# #pw+986 472 511 426 477+7# dial this codes
Jan 08, 2009 | Nokia N95 Cellular Phone
TEC B 472 QQ
Swapping the parallel port to the printer should allow it to connect via parallel. Run through front panel diagnostics before/after install. depending on firmware it will tell you if the parallel board is installed.
Nov 09, 2008 | Toshiba TEC B-472 Thermal Label Printer
Hiiiiiiiiiiiiiiii
Hi
Try it on any other PC. if other usb devices work with your PC you may have dirty contacts of your USB.
Aug 29, 2008 | Delstar DS 31024 MP3 Player
TEC 472 QP PRINTER
Try with CUPS --- oh, sorry, it's for Linux only, my bad
Jan 08, 2008 | Toshiba TEC B-472 Thermal Label Printer
Nokia N96 Smartphone Logo
44 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
