Question about Transmission & Drivetrain for Ford Transit Connect
Would like overdrive in 83 ford bronco 300 6, 435 4speed its cherry one owner. i have access to a new rebuilt 5 speed out of 87 ford ranger v6 4x4 can it interchange?
Interchange possibilitys
  • 92 Answers
No it will not.
Posted on Mar 16, 2015
    Sergeant:
  • Ford Expert
  • 340 Answers
If the bellhousing from one can be put on the other, in theory, it should work. Just keep in mind that the torque horsepower of the 300 6 could totally splatter the 5 speed out of that flyweight Ranger.
Posted on Mar 23, 2014
1986 ford ranger wont shift into overdrive
could have faulty governor.throttle cable need adjustment.the 83 - 90 models you need to adjust front and rear bands in the transmission.
Apr 06, 2013 | 1986 Ford Ranger 2WD
Transmission oil for manual 5 speed 1984 ford bronco
use an 80 grade oil
I personally use oep 80/90 in the transmission because of the high teeth load in overdrive
Aug 19, 2012 | 1984 Ford Bronco II
Hooking up my overdrive
You must buy a special kit and install a electronic speed sensor for the kit into the transmission. Google Ford C6 OD kit"
Feb 14, 2012 | 1987 Ford Bronco
What causes 87 rangers transmission to change back and forth from 4th to 5th between 35 & 55 mph
probly a worn trans--try ajustin the tv-cable 1st-its attached to carb and gos to the gears to shift them--get a pressure test done and a test drive by a pro--if he sez rebuild u may want to hold off cause its only an overdrive issue--when clunking--slippin--or no motion---then a jaspar rebuilt is the choice
Nov 07, 2011 | 1987 Ford Ranger
Transmission stuck in overdrive on a 1988 Ford Bronco II 2.9L V-6 with a 5-Speed on the floor.
Sounds like a gear lockup, two choices take transmission out and find someone to rebuild it or would have to go to salvage yard and find another one. a new rebuild is approx 1,300.00 or salvage yard is approx 300.00..
Dec 12, 2010 | 1988 Ford Bronco II
Where do i find a transmission for a 1987 bronco 2 or ford ranger
I would check car-part.com. It's a website that will show available parts for your car from auto recycler's in your area.
May 08, 2010 | 1987 Ford Bronco II
Which 5 speed transmissions will work with an 89
all the early rangers up to the genII and maybe even more will work in you bronco....join the ranger station forums for a lot of insight on your bronco...
Mar 01, 2010 | 1989 Ford Bronco II
1989 ford ranger- "D" vs overdrive
Overdrive is designed for highway use, to lower the engine's rpm's and conserve fuel. It will not hurt your vehicle to drive it in drive in the city.
May 28, 2009 | 1989 Ford Ranger
Overheating intown or towing
You might laugh, but have you put a new rad cap on? If the system is not holding enough pressure it can overheat.
Aug 01, 2008 | 1988 Ford Bronco II
Transmission & Drivetrain for Ford Transit Connect Logo
110 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
