Electric window not working in 1997 ch mack
Trying to replace electric window switch in 1997 ch mack with new model switch, need wiring diagram
SOURCE: wiring diagram for lights for 1997 nissan xe pickup
don't no how to take off taillight lens to cange bulb
Posted on Dec 15, 2008
  • 975 Answers
SOURCE: 2005 Chevy Cavalier Electric Window Wiring Diagram
Tom,
See this alot. Sorry,It appears that is a symptom of a bad motor. If it moves an inch or so,then nothing,after a few minutes another inch or so,it's motor time!
Posted on Apr 08, 2009
  • 174 Answers
SOURCE: need wiring diagram for switch.......
try looking at this site .http://www.toolpartsdirect.com/cgi-bin/partbrands.cgi
Posted on May 31, 2009
gewiz
  • 1271 Answers
SOURCE: Need service manual or electrical wiring diagram.
one ofthe best ways to work it out is the find the motor controller, normally it's a black box located under the seat,
Now remember you have two wires from the batteries B+, B-, two wires to the motor, M+, M- and some smaller wires on maybe a ten connector block that leads to the tiller where the throttle on the handlebars is located.
Hope that helps
Regards
GeWiz.
Posted on Oct 02, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have a old Bryant
www.bryant.com
www.furnacepartschicago.com/.../bryant-furnace-parts
Posted on Oct 21, 2009
Spark plug wire to distributor cap diagram 291 mack truck 1961
If you haven't removed the wires yet don't. The best way to replace ignition wires is to remove ONE at a time and replace with a new one before moving on to the next. That way you won't get the firing order mixed up. Hope this helps
Oct 11, 2014 | Cars & Trucks
I have an 2003 Acura TL-S. The drivers window will not go up or down. try the new switch and checked the motor both are fine. fuses all check OK. But can't fine the relay to check
Until you get yourself a wiring diagram & change the
way you go about testing electrical circuits-your done
Why a new switch--no testing of the old one?
Checked the motor how-removed the door panel
& put battery voltage directly to --it in both directions?
All the other windows work?
No power to the window switch (need wiring diagrams there)
Wiring going into door not a problem !
Sep 24, 2014 | 2003 Acura 3.2TL
Power windows dont work on my 1993 s10 blazer.
Test the electrical circuit , Using a DMM - digital muti-meter an wiring diagram ! Voltage drop testing ,
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Electric Testing Techniques You Need to Know
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model an engine size . Under system click on body & accessories ,then under subsystem click on power windows . Click the search button ,then blue link.
Check for broken wire's inside the flex connection from body to door .
Nov 13, 2017 | 1993 Chevrolet S-10 Blazer
My window wipers on my 1996 Chrysler Sebring 2.5L V6 does not work. I turned them on and they came on for about 1 minute and when I went to turn the wipers off, the wipers did not go all the way down and...
Could be a few different thing's . The motor , relay , BCM - body control module , the switch etc.... Looking at a wiring diagram (do you know what a wiring diagram is ? ) I see fuse #15 10amp powers the wiper switch , the switch is an input to the BCM , The same fuse supply's B+ voltage to the control side of wiper hi/lo relay & the intermittent wiper relay . The BCM will energize these relay's after it receives a input from the wiper switch . Do you know how to test automotive electrical circuits using a wiring diagram an a DVOM - digital volt ohm meter ? Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine . Under system click on body & accessories ,then under subsystem click on wiper/washer . Click the search button ,then the blue link . Having the BCM check for DTC'S - diagnostic trouble codes would be a good first step , could point to the problem . Electric Testing Techniques You Need to Know
This is how to diagnose electrical problems .
Jan 31, 2018 | 1997 Chrysler Sebring
Passenger power window not working
Check the wiring inside the rubber boot from the body to the door . Opening an closing the door a million times can cause these wires to break . Testing the electrical circuit using a DVOM - digital volt ohm meter before replacing parts is the proper way to diagnose automotive electrical circuit's . You can find free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click body & accessories ,then under subsystem click on power locks or windows ,which ever you want to diagnose first .
Suggest you watch this video as well
Oct 09, 2017 | 1998 Ford Windstar
1997 grand prix window won't work
Do you need a new motor
How would someone know that?
You need a wiring diagram or at least
match up the cut wires,solder & heat shrink them
Then diagnose the motor,switches,etc
I buy factory wiring diagrams for all my vehicles
I never approach the vehicle without them
One quick check of what does work,then into
the wiring manual
You can not repair something you know nothing about,
need reference material
Helm.Com ---for manuals & lots of money
May 24, 2012 | 1997 Pontiac Grand Prix
I have a 1997 Buick LeSabre and none of the electric window switches are working except the rear passenger switch. The rear driver switch was working but it stopped with the window down. I want to get...
Take off the door panel and disconnect the two wire plug one is brown the other is orange. Take two jumper wires and run them to a battery. If it goes down then switch the wires on the battery and it will go up. If it does not move then the window motor is shot and will need to be replaced.
Mar 13, 2011 | 1997 Buick LeSabre
1997 Chevy Lumina, I replaced the passenger side power window motor due to the factory one failing, The person before me cut all the wires going to the motor and toggle switch in their attempts to fix /...
There is a wiring harness on hinge side of passenger door correct, take a look at the wiring colors. Hope you can read it. At the window switch, the outside wire on either side is voltage or ground depending on which direction, up or down, reversing motor. You don't need the window switch for testing, you should be able to operate from driver door master switch. If you get the wires reversed, the only thing that will happen is, up will be down and down will be up, if that happens, reverse the wires. Just my opinion.
At the window switch, top middle wire is lockout, so only the driver can operate the windows.
Apr 26, 2017 | 1997 Chevrolet Lumina
The only electric window that will work is the front passenger side and now the electric locks will not work either. Is there a fuse that needs replaced?
In the Fuse Block, check the CAVITY 26, Fuse 30 AMP C/BRKR
Check the wiring, maybe is broken; also, you can check this information:
- ZJ-Secc-8S-Power-Windows
- ZJ-Secc-8W-Wiring-Diagrams
Good luck, and remember rated this help.
Aug 17, 2009 | 1997 Jeep Grand Cherokee
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
