Question about Air Tools & Compressors
G force air compressor com
AM AFTER A REST SWITCH FOR G-FORCE AIR COMPRESSOR MODEL WA-FG21IP 2HP 21LT
  • 98 Answers
SOURCE: Air compressor won't build pressure
If this unit has what appears to be a pipe with fins on it , you may have a ruptured inter-cooler which will be leaking where you stated.
Posted on Jul 21, 2009
protek480
  • 1723 Answers
SOURCE: My PRO-SOURCE air compressor will not go over 50 psi
Your compressor has got a 'ring' problem. The rings on the pistons that compress air are leaking air by them and need to be replaced. Unless it's the 'pressure release' leaking. When it gets to 40 PSI or so, unplug it and listen for a leak. If no leak then it's the rings. inside on the piston. If you adjust the pressure switch all the way low, it might shut off near where it builds pressure to and you could at least use it some.
Posted on Sep 26, 2009
louislevel_2
  • 374 Answers
SOURCE: My dad bought a used 2HP 4 gallon clarke pancake
hi there!
some motor compressor are equipted of centrifugal switch connected at the shatfting of the motor compressor after turning at rated speed this will be open and disconnecting your starting circuit as well as the starting capacitor.
have anice day fix my rate, thank you
Posted on May 08, 2010
  • 1388 Answers
SOURCE: I need a maintenance manual for model HL700200 air compressor
The following address will provide you with all the info that you need to maintain your compressor. Good luck
http://www.chpower.com/webapp/wcs/stores/servlet/XItemDocuments?storeId=10051&langId=-1&catalogId=10001&findModel=HL7002
Posted on Jul 12, 2010
SOURCE: How much oil for 2hp 8 gallon central pneumatic air #95386
i'm not sure of the solution but what type of oil did you use?
Posted on May 29, 2011
CAP 2060P air compressor won't start. How does the red on/off switch work? Ours just turns and hard to tell where it is supposed to be. Also, is there a reset button someplace? Thanks.
The pressure switch installed on your unit is of the pull / push type. Let all the air out of the tank and plug it in to wall outlet. Push red knob in firmly then pull out for desired results. The pressure switch contacts can fail but usually after many hours of hard service. No reset /thermal breaker is listed on the replacement parts list. You can view at WWW.bostitch.com click on service / parts then look for your model number from the pull-down list. Good luck with your compressor.
Apr 17, 2011 | Stanley Bostitch 2hp 6gal Air Compressor...
COMPRESSOR ON RESTART DOES NOT GET UP TO SPEED. SOUNDS LIKE IT IS UNDER LOAD. DOES THIS COMPRESSSOR HAVE AN UNLOADER VALVE ON IT? IT ACTS LIKE IT CAN;T GET UP TO SPEED BECAUSE IT IS UNDER PRESSURE.
Yes it has an unloader valve on the rear of the pressure switch. Replacement will depend on the model of the power switch, they used roughly three different models on this compressor.
Tim
Mar 06, 2011 | Hitachi EC12 Portable Electric 2hp Air...
I have a 2hp twinstack air compressor model IBM# 606-4349. The pressure switch (part # 58) will not sut the compressor off theeby blowing the relief valve. The compressor is brand new. my e-mail is...
Hi wl, my name is John. Welcome to FixYa. You need to replace the pressure switch. You can get it here. www.mastertool.com . Make sure to unplug the cord from the outlet. Remove the two screws and air line, disconnect the wiring. Install is reverse of removal. Thanks for choosing FixYa. Good luck, and Happy Holidays.......John
Dec 16, 2010 | Mintcraft Air Compressor 1 HP 4 Gal
Hitachi EC 12 2hp Air Compressor. Just get a buzz sound when plugged directly into 120v wall outlet. Piston and shaft turn freely. Have installed a new pressure switch. Just turned the compressor on...
Hitachi EC12 Air Compressor Parts : MASTERTOOLREPAIR.COM
Here is a site that says:
1. Are the capacitors good? (They get the motor going).
2. If they are, replace the stator, ($245)
If you don't find a good solution there, I would try taking it to a local motor rebuilder.
Gary
Dec 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My dad bought a used 2HP 4 gallon clarke pancake type air compressor at an auction. It keeps blowing capacitors. Does it have a centrifical switch to take the cap out of the cct once started?
hi there!
May 07, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Apr 10, 2010 | Air Tools & Compressors
Hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Air Tools & Compressors Logo
37 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
