Sound cuts out.
Sometimes the sound cuts out.Pushing on or rotating the speaker selector switch brings it back. Happens many times during the day at random. Sony model STR-DE935
Thanks.
  • Audio Player... Master
  • 5,515 Answers
Bad solder joint. Dirty contacts (servisol switch cleaner) or a broken switch. I would have thought!
Posted on Jun 20, 2009
Why does my shs audio pod4 amp keep cutting in and out?
Without knowing the circumstances of the usage, it is not possible to give an accurate answer, but try rotating the input selector switch throughout the full range of movement a few times (to clean the contacts) The problem may be that you are overdriving the speakers and the cutout in the speakers is doing what it should. Try turning it down a bit and see what happens. They aren't designed to be used at max output continuously.
Apr 07, 2012 | Computers & Internet
Connected home cinema today and cant get sound when watching the tv
no sound out of tv?
sometimes that happens and you need to wire sound back to your tv from your amp. usually normal audio cables work.
or if you have no sound on your stereo from the tv.
you must have cables hooked up wrong or your amp is on the wrong selector eg. tuner,tape,dvd,cd. etc
Feb 21, 2010 | Panasonic Audio Players & Recorders
Left speakers sometimes cut out and leave just a high treble soun
please check the input connecetor could be the losse conact with the wire some times it happens with this type of sound try to play the system and move the connector if the sound trun go replace the input cor
Nov 07, 2009 | Audio Players & Recorders
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Sep 07, 2009 | Pioneer VSX-816-K/S Receiver
Right loudspeaker problem
Doesnt sound like the selector as it "sometimes" works. Redo the speaker connections on the back of the amp and speakers first. If it persists, swop the speakers and cables, if the problem swops, then it could be inside the speaker or the cable, if still the same then amp has dry joints/loose connections probably
Jun 24, 2009 | NAD C372 Amplifier
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
Durabrand DB1215 car radio
I have a db 1210 and i need the wireing plug for the speakers can you help
Jun 04, 2008 | Durabrand DB1200 CD Player
Yamaha DSP A-1000 input selector switch not working properly
i did not post that....and why would fixya be asking the poster of a problem for a solution?????
Bug? Pls delete these posts moderator.
ty
Mar 09, 2008 | Audio Players & Recorders
Reciever troubles
Slapping the unit causing the missing sound to come back tells me that there is something loose in the receiver. This could be a bad solder joint or dirty switch contact. Vibrations, such as sound, could be jarring the bad connection and causing the sound to cut out when it was just working a few seconds before. I don't believe you have a bad part in the receiver. When a solid state device fails, its gone for good. Again, it soulds like a bad connection. Finding a bad solder joint can sometimes be difficult. What you need to do is take the cover off so you can see the bottom of the PC board and using a good light source and magnifying glass, look for the bad connection. You can try running the receiver with the cover off and using a plastic pen, try pushing down on the PC board and see if you can make the sound cut out. You may be able to isolate the area by where you push on the board. Look for loose wires too. While you have the receiver open, buy some electrical contact cleaner in a spray. Radio Shack used to sell this as TV Tuner cleaner. I don't think they carry it anymore though. Spray the switches and rotate them back and forth several times. See if this resolves the problem. If you do find a bad solder joint, all you have to do is resolder it with some new solder. Make sure you do this with the power OFF. You're not looking at a big bill here. It's an easy fix once you find it.
Good Luck.
- Jim
Mar 01, 2007 | Sony STR-DE445 Receiver
43 people viewed this question
 Grubhead
Grubhead
