Question about GE WBSR3140DW Top Load Washer
My Maytag kept filling for the rinse cycle and overflowed, I do have a new cat hair problem...could this be from a clog somewhere?
  • 530 Answers
No. the problem is either your pressure switch or the pressure hose has a hole in it.
Posted on Jun 14, 2009
  • erica graber Jun 14, 2009
    or also your fill valve could be sticking open does it fill when it is turned off?
Eev99413 washer overflows on rinse.what would be the problem?
Possibly one of 3 things:
The pressure valve that flushes the water out could be bad.
Or, the drainage may be clogged somewhere. This happened to us after we washed 4 or 5 cheap Walmart rugs with that no slip rubber stuff on the bottom. The rubber stuff disintegrated and clogged the drainage up extremely tight, looked just like cat litter.
Or, the relay switch that controls the pressure valve could be malfunctioning.
Good luck.
Jan 11, 2018 | Washing Machines
Why won't maytag MVWC6ESW go into rinse cycle?
The cold water valve screen in the washer water valve is clogged. You have grit in your water and it will continue to happen until you get a filter system installed on to it.
Mar 18, 2016 | Maytag MVWC6ESWW Washer
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
When it goes through rinse cycle and starts to pump water out of the machine, the drain pipe fills up and overflows, then it will rapidly drain.
Usually there is a clog or restriction in the stand pipe(drain pipe) causing water to not drain away.....Suggest drain-O products.
If you have a very long drain or the stand pipe is not above the water level in the tub you will want some type of air gap to prevent siphoning.(siphon break kit)
good luck
Mar 14, 2010 | Maytag Atlantis MAV6451 Top Load Washer
I have a Maytag Jetclean and it doesn't rinse well
Probably unlikely that it's clogged, but rather defective.
Feb 25, 2010 | Dishwashers
My washer machine is overflowing at fill up and rinse cycles.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear
Dec 22, 2009 | Maytag Washing Machines
When it hits the rinse cycle it fills full of water
sounds like your pressure switch. Less than £20.00p
May 19, 2009 | Maytag Washing Machines
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Apr 16, 2017 | Estate ETW4400VQ Top Load Washer
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
GE WBSR3140DW Top Load Washer Logo
46 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
