Question about Briggs & Stratton Gas Pressure Washer 20244
Briggs and Stratton power washer starts and then shuts off
If I keep pushing the prime button it will continue to run but it takes multiple tries.
Editor925
  • 285 Answers
SOURCE: Pressure washer with no pressure
Are you priming the water lines before you switch on the power?
i.e. with power OFF, hook up hose and turn hose on (doesn't need to have much hose pressure), then take your spray gun or attachment and pull the trigger and allow water to flow through the system (at hose pressure obviously). You might need to gravity feed it if its not flowing through...
But you will generally only get pressure once all the air is removed from the lines and the pump is pushing water only... Once you have water flow and lines are primed, switch on pump and see if that solves it.
Posted on Mar 17, 2009
  • 174 Answers
SOURCE: Briggs & Stratton engine loses power
Hello herb1007
If it is running it would burn any oil off the top of the piston. (that got there when you tipped it). It sounds like you carburetor needs cleaning. There are sprays on the market that sometime help with this.
Posted on Jul 16, 2009
sr6248
  • 66 Answers
SOURCE: Briggs and Stratton pressure washer will not spray
The nozzle on the end of the spray wand has a very small hole in it that can be easily clogged by any sort of debris that comes through the water supply.If the nozzle can be removed, just take a pin & clear the hole from the outside & rinse it off. If the nozzle can't be removed, then take the wand apart at the connector in the middle and do the same thing.
Posted on Jan 30, 2010
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
SOURCE: I have a Briggs & Stratton pressure washer,
If #1 doesn't work, the ports in your carb could be clogged. I just dealt with this problem this weekend. This is a relatively easy fix. Locate your carburetor and find the aluminum bowl underneath. On the bottom of the bowl, you'll find a bolt. Loosen the bolt (gasoline will come out because the bowl is a reservoir for gas, but please make sure you've turned the gas supply off) and remove the bolt and the bowl. Clean any debris out of the bowl. The ports are holes in the bolt you removed. Make sure that air can pass through these holes (I blow through them, but I don't mind the taste of gas too much. Probably NOT healthy. You can use thin wire, carb cleaner, etc..) Reassemble and your motor may start, if this was the problem. Make sure that the bowl seats properly and that you are careful screwing in the bolt, lest you cross-thread it. Hope that helps.
Posted on Apr 29, 2010
Dynamark 3.5 Model 20211X18A. Looking for manuel, I prime 2 times to start. Engines starts then dies. If I continue to push prime button it will keep running, barely, however, dies as soon as I stop...
Could be 2 things: a restriction in your fuel line/coming out of the tank, or 2: a dirty carburetor needing to be removed, cleaned and possibly rebuilt and reinstalled. Hope it's one of those.Start with pulling the fuel line loose from the carburetor. If you have fuel flowing freely, plug the hose with a golf tee and move onto removing the carburetor. Carb kits are cheap and easy to install. It's best to rebuild while you have it off to avoid similar problems later.
Sep 30, 2013 | Briggs & Stratton Briggs Stratton...
Fires up good but dies out?
you have a plugged primary jet in the carb
Aug 04, 2012 | Briggs & Stratton 3000 PSI Pressure Washer
I have a craftsman briggs and stratton 550 series silver edition lawn mower and when i turn my lawn mower on the engine revs and then lets of over and over again like it is about to die but dont... what...
i have a brand new craftsman briggs &stratton silver engine series 5.50 158cc it will start but will not run unless i keep pushing the prime button to give it gas once i stop so does the engine
Oct 22, 2010 | Garden
I can get my briggs & stratton push mower to
Your carb needs to by cleaned out. Needs to be taken apart and cleaned with carb cleaner. There is also a gasket that needs to be replaced. It collapsed and not letting gas in the carb.
Jul 07, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Mower shuts off 3 seconds after priming
Briggs made primers with and without holes in them. In my shop it is common to see them transposed on engines.
Take down the MODEL TYPE CODE numbers and check here to see if yours should have the primer with or without the hole in it.
Click the Parts Lookup box in the center of that page.
Next, drop down the menu on the left to Briggs & Stratton. Set the tab at the top to MODEL.
Next, type in the model number and click search.
From the results page, select your exact type number. Your individual parts views will then be listed on the right side of the page. You'll get the idea!
Hope this helps.
Sep 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Mar 17, 2009 | Briggs & Stratton Pressure Washer...
Lawn mower
i dont understand the pulling the button - do you mean push the primer button - if you mean primer button it sounds like the high speed jet in the carb is dirty and needs service- you can attempt to start and once engine fires have someone continually push primer to keep running it ma clear the blockage - did You check the fuel tank for any water ?
Oct 19, 2008 | Mtd 22" Yard Machine Push Mower
Briggs & Stratton Gas Pressure Washer 20244 Logo
982 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
wadingriver
wadingriver
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
