Question about Sony Audio Players & Recorders
I have an old Sony X33ES single disk CD player which I love...I bought it new. It suddenly has a buzz in the audio coming from one channel, and the volume is down on that side. I obtained a schematic of this machine, and see that there are two op-amps in the audio amp circuits. One IC is a M5220P, and the other is a NJM5532D. I can find the NJM5532D, but cannot find a replacement for the M5220P. Any ideas?
sapperj
  • 70 Answers
SOURCE: Buzzing from speakers
First, let's distinguish a buzz from a hum. A hum is a clean, 60 cycle signal that sound like a tone. A buzz is 60 cycle noise created when the power filtering circuit is not doing it's job. This is basically a 60 cycle hum, but because of the way the faulty filter reacts, it "distorts" the signal slighly and is a buzz. Trust me on this if you don't want a full electronic explanation. If you are curious and would like one, email me seperately.
If it is a buzz, chances it is the filter capacitors, but lets not jump to that conclusion yet, this can only be fixed by a professional, so let's try the free fixes first!
You might have 1) a ground loop, 2) faulty house AC. What is the age of your house? Are you using any three prong to two prong adapter? If so get ride of them.
But the first obvious thing is to look inside the unit and see how dusty it is. UNPLUG FROM WALL before opening. Use a can of compressed air if necessary. Now try. Dust build-up causes static electricity with can play havoc with electronic componenets, but normally not 60Hz, but it's worth a try.
Before I get into the ground loop, do you have any flouescent lights in the area? These use transformers which tend to put a 60Hz buzz through wiring it is directly attached to, but only when on.
Check if this buzz is consistant with any selected device (DVD, CD, Radio, etc.). If it is true of all, continue on, if of one, disconnect that particular device and see if it stops. Just turning off a device still keeps it in the elctrical loop...
A ground loop can be caused by a broken wire. It is important that every compnent be grounded to a single point. With a broken wire this can cause multiple paths to ground. disconnect everything, all components from the receiver, antennas, any cable running to another component, etc Just leave the main speakers hooked to the receiver and turn it on. Hopefully you have "audio snow" but no buzz. This method is called isolating the problem. If the buzz disappears skip to the 2nd paragraph. If you still have a buzz: unplug unit from wall, try a 3-2adapter into the wall. If this works, you have a faulty ground. Bring receiver into another room and try. Same result with buzz? (with or without 3-2). Go to a hardware store and purchase a ground fault indicator and make sure your house wiring is OK. Very inexpensive part. You simply plug it in a the lights tell the story. Usually two yellow lights and one red. Both yellow on indicate everything is fine.
Up until this point I am taking it for granted tht the power cord from the receiveris three pronged. If it is NOT, try running a thin wire from the outlet (attach using the center screw that hold the outlet cover in place) to a screw on the receiver. It would not hurt to try this even if it is a three pronged connector in case there is a broken ground within the unit.
Hook up and test each component until you hit the one the causes the buzz. When this happens, try using a different cable as this one is probably broken. If it doesn't stop, try what we tried for the receiver, if it is a three prong electrical plug, use a 3-2 adapter, still buzzing, now try adding the extra thin wire between the two compnents.If it a two prong, add the ground wire from the component to the receiver.
If all else fails it needs to go into the shop. But I will say this. Compare the cost of getting an estimate/repair with purchasing a new unit. It might actually be less...
Hope this helps,
Jeff
Posted on Jan 14, 2008
  • 112 Answers
SOURCE: sound from only one channel
If there is a headphone output on the unit try listening through it to see if the sound is in both channels. If so,it is likely a dry / fractured solder joint on or near the jack connector. If not it could point to a failure of the digital -> analogue convertor IC chip.
Posted on Jan 25, 2008
  • 15 Answers
SOURCE: Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
Posted on May 27, 2008
jomabug76
  • 1148 Answers
SOURCE: Technics SL-PG440 CD player no audio output
GET NEW RCA JACKS
Posted on May 15, 2009
  • 62 Answers
SOURCE: schematic ?
Hello
This will help you
http://www.guitartrader.com/!OL10BXPVIk3X3pt0Y2E!BQ!/Marshall-MG100HDFX-100-Watt-Amp-Head
Thanks & Regards
Posted on May 24, 2009
I have a technics SL-CH505 compact disc but it will not play burnt CD;s any suggestions my other technics SL PG 400A plays them noproblem
The Optical Pickup(laser) may be weak. It takes much more power to record than play, which I guess it works.
Oct 13, 2014 | Technics Audio Players & Recorders
I can play audio CD but CAN NOT PLAY DVD or BURN DVD on LG GE20LU10
Hello, Your computer will automatically install the basic drivers for the burner to view cds but to burn a dvd or music cd or data cd or photo cd you will need software to do so. Windows XP and newer operating systems have a simple burning software using Windows Explorer which will pull the appropriate application automatically. I recommend a program such as Nero which originally comes with most burners. But for a more advance and controlled burning program Roxio has the easiest and most versatile program for about 50.00. Keep in mind if you want to make back-up copies of bought DVD movies or software you will have to have a specific program such as DVDFab. I can send you a copy of the actual software Cd that originally comes with your burner if you need it as I have bought several LG burners which now I have multiple copies of the software with OEM Keys. They have Nero V6.6 which is good for simple disk burning. Also keep in mind when buying blank disk NEVER buy the cheap unknown brands or the cheesy store brand disks as you will waste more disk due to bad coatings than you would if you bought better brands such as Memorex or Sony. Verbatim brand is a good inexpensive disk perfect for learning how a burner works due to the cost being reasonable and if you make a mistake burning the disk its not as bad a monetary loss. After you learn how to use the burner and program and you are ready to make good permanent disks then get an archival type disk with at least a 50 year storage time, (Your local computer store will help you with picking out the right kind, these disks are expensive but if you want to store vital photos or such this is the kind you need). Also A DVD-R is the most versatile disk for most players old and new and a DVD R if more for burning on the "fly" and for newer expensive players. A CD/DVD
Aug 15, 2010 | LG GE20LU10 AUAE10B DVD±RW Burner
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
1997 Chevy Pick up Single disc player won't work
Have you tried different CDs?
If the cd is ok, the read head on the cd player is probably covered in grunge! Get thee to ye olde local audio / TV shop and purchase a CD head cleaning kit.
Usually these come with a cd with a brush attached to it and some cleaning fluid.
Follow the instructions on the packaging and give your music cd another try.
Hope this does the trick
M3ODQ
Feb 01, 2009 | Car Audio & Video
Audio won't play on DVD - but it will play for CDs
Hello, you can verify that your receiver is working or not. When you are playing a dvd unplug the audio RCA plugs (red and white) from the back of the Sony dvd player. Touch the tips of each of the RCA plugs with your fingertip. You will hear a buzz sound coming from the speaker associated with the plug if the receiver is working\ i.e. touch the red RCA plug tip and the right speaker will hum...touch the white tip and the left speaker will hum or buzz. This will not hurt your system or speaker. If you do not hear the hum turn the volume to 3 or so and wet your fingertip and tap the tip of the RCA connectors. You will hear "pops" coming from the respected channel. I believe your cd\dvd is at fault. Good Luck!
barneyluc
Oct 02, 2008 | Yamaha HTR-5440 Receiver
Buzz in Samsung Digital when DVP-NS57P Sony is played back?
Greetings,
Check the audio connection, the port on the TV might be grounded.
While playing, try moving the connection in the port.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 08, 2008 | Sony DVP-NS575P DVD Player
Code for Sony Car Stereo CDXm610
You can find code on manufacture site! Just follow instruction and you need serial number that you got with yours CD player.
good luck
Jun 16, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Sony CDP-CX455
did you have any luck with swapping the channels to determine if which is bad, cd or system?
regards
Graeme
Mar 28, 2008 | Sony CDP-CX210 200-Disc CD Changer
Audio input/output
It sounds very much like your receiver needs repair by Sony.
www.esupport.sony.com
Sep 06, 2007 | Sony STR-DE998 7.1 Channels Receiver
MP3 files start skipping/popping after few minutes of playback
Sony say in the manual that if you record high bit-rate mp3's the sound may be intermittent. I feel this is due to the decoder having to move ALOT of bits around to play, try some makeing a disk with mixed rate mp3's on. e.g.) some 64Kbps, some 128, some 192, and some as high as you can get and see if there is any differ Luck
Mar 02, 2007 | Sony CDX-MP40 CD Player
464 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
