Question about Dryers
Hoover condenser tumble dryer is blowing cold air
Hoover condenser tumble dryer - HNC 172 S NEXTRA 7 is blowing cold air only ,and the filter care light is always on
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    This maybe a dumb question...have you cleared the filter.... also inspect the air duct..sometimes this will fill with cotton debris?
2 Suggested Answers
hards327
  • 30 Answers
SOURCE: How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
I have a Hoover nextra 6 kg condenser tumble dryer which is leaking water and the collector is empty and seems not to locate fully into the hole at the back?
Check for Lint/Dirt in the Drain and then you need to ensure it is fully connected in the Washer to the Drain...
Jan 03, 2015 | Hoover Dryers
I have a hoover nextra dryer hnc 170. The drum will not turn, and both the lights for filter care are on. I assume the reason it is not turning is because of the filter care light. Is there anythin i...
the filter care light comes on when the machine is over heating so the "brain" thinks the lint trap is full , clean the entire venting system, including the outside vent cover and remove any debris , then unplug the machine for a few minutes and see if it resets
Jul 04, 2011 | Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
May 14, 2009 | Dryers
Hoover Nextra 8 dryer making a squealing noise
you have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Dryers
Tumble Dryer not getting hot
its your thermostat mate they cost 30quid simle to fit
Jul 06, 2008 | Dryers
Hoover nextra mega load 7.5kg HNC175 condenser dryer has 1)stopped heating, the drum still goes round and cold air goes in. 2) The filter care light is on, i have taken out the condenser assembly and...
On the rear there is a Heating element hidden under the silver cover, on the top of this unit, there is 2 thermostat's, one is a auto-reset set (On the left) around the 100'c mark and one is a single use thermal trip set at 130'c (on the right, also denoted by a blue spot), the idea is when the heater reaches 100'c is powers off until the air temp drops, once it drops the auto-reset kicks in and forses the heater to power back up, however, in the intrests of safety, if the auto reset fails to power down then the 130'c thermostat will permenently remove power from the heater and will illuminate the filter care light, the only way to restore the power to the heater is to either have an engineer replace the whole heater as Hoover/candy do not sell on the thermal cut out to anyone.
you can usually find the heater unit for £30-40, an engineer may charge upto £140 for the same part and fitting.
Apr 03, 2008 | Dryers
Mar 14, 2008 | Dryers
Hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Feb 26, 2008 | Dryers
Dryers Logo
336 people viewed this question
Top Dryers Experts
Marvin
Marvin
