Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
HOTPOINT WD420 TRIPS ALL THE SOCKETS IN MY HOUSE
My Hotpoint WD420 trips the power to all the socckets in my house whenever I try to start the machine up.
    President:
  • 1,185 Answers
You have a fault on the machine which is a dead short or an earth leakage.
Neither can be sorted out without a set of testers and some knowledge
Unless you can get hold of a resistance checker and know how to use it call a in a repair person
Posted on Jun 14, 2009
Hotpoint wml540
Wire or component is shorting out. You may have to hire someone to find and repair it.
Nov 20, 2017 | Washing Machines
We recently bought a new Hotpoint WMF760P washing machine and within a couple of weeks of using it noticed that it kept tripping all of the electrics out in the house, when it goes into it's final fast...
I have seen this before with a number of machines when they were a little overloaded. I've never been convinced that I understood why it happened, though I always suspected a motor overload of some kind causing the issue. This said. There is absolutely no reason for a machine to trip the mains unless it's faulty.
If you have a friendly neighbour who doesn't mind you killing the power in their house, you could always run an extension lead from a neighbour to your house and see if it kills their power too. But like I say, at the end of the day, if it trips the power and you have your electrics checked, then I would INSIST that you get a replacement from Hotpoint. Things that use water and electricity are not to be messed with!
Sep 08, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi, i have a hotpoint WMA37s and half way thru a cycle it tripped my house fuse box. I changed the fuse and tried other sockets in the kitchen but it still trips the fusebox so i am assuming it is the...
It could be the heater, when you said halfway through a wash that would be about 20 minutes or so but the heater would have come on after about 10 minutes, but it is worth checking out (with a meter) or it could be a build up of carbon from the brushes, in which case a quick dust out of the motor housing will clear that. The other possiblity is a wire shorting out on the cabinet, this one is not so straight forward and will need some tracking down. If you have a Megger then do an insulation test for information on this use this link. http://www.selfix-uk.co.uk/Megger.html
Mar 03, 2010 | Hotpoint Aquarius WD640 Front Load...
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Aug 15, 2009 | Washing Machines
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
Jul 19, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Machine fuses house RCD if a drying cycle is selected
Suggest you turn the power off, remove the top cover, diconnect the live and neutral connections to the dryer element (likely to be two of each flavour of connection if the machine has high and low dry settings). Pop a bit of insulating tape around the wire ends so you don't short anything out. Now try to put the machine through a drying cycle. If it works (albeit cold) without tripping the house power, you need a new dryer element. If the house power still trips, turn the power off again and without reconnecting the element wires, disconnect and tape the live and neutral wires from the blower motor. Again, try to run a drying cycle. If this stops the house power tripping, then it looks like a motor problem (though this would be quite unusual). If the house power still trips, you need to have a careful look at all the wiring between the main timer, the dryer timer, any hi/lo heat switch, the blower motor and the element with its associated thermostats and thermal cutouts (all located near the element on the air duct). Look in particular for chafes where wires go round corners, and where wiring crosses from the case to the suspended machinery in the middle of the machine. Pop any follow-on queries in the comments section of this question - I'll keep half an eye on it. A.
May 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
553 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
