Question about McCulloch FHH18A Electric Pressure Washer
Loose inlet valve leaking on FHH18A
My 1 1/2 year old McCullough FHH18A pressure washer has a significant leak at the inlet valve (immediately adjacent to the garden hose connection). This is not a leak at the hose connection, but rather it is because the whole inlet valve is loose. I'm assuming that this is affecting pressure, and it definitely creates puddles while the unit is running. Can this be tightened? How? Ideas?
Also, I misplaced the User's Manual document. Can I find an electronic copy online?
  • 104 Answers
SOURCE: pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
Posted on May 26, 2009
  • 174 Answers
SOURCE: fhh18a water flows INTO the tanks during operation.
There should be a ball and spring in the valve where you attach the soap suction hose.
Posted on Jul 05, 2009
SOURCE: McCullough pressure washer
I nedd a manual for a FHH18A pressure washer
Posted on Apr 13, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I need a manual for a McCulloch pressure washer
Your manual can be downloaded from here:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2006/MOUS2006_7096H18A01.pdf
If the above link does not work start here: http://www.mccullochpower.com
Which should get you to this page where you type in FHH18A as the model number
http://www.mccullochpower.com/node7877.aspx (Use for ANY McClloch
Course of last resort.... Call them at this number: 1-800-521-8559
Thanks for choosing FixYa,
Kelly
Posted on Oct 18, 2010
  • 1388 Answers
SOURCE: I have a broken plastic inlet valve for the water
May I suggest replacing this plastic part for metal parts (parts for 16 year old unit most likely not available) available thru www.pwmall.com or other pressure washer parts houses. Look thu parts listings and purchase adapters with correct thread /fitting type for your application. They will assist you with your purchase. As an example, view the following link for adapters.
http://www.pwmall.com/s-20873-twist-connect-couplings.aspx
Northern tools also has a very good selection of fittings to solve your problem (Northern tools Co are in most larger cities). www.northerntool.com
Good luck
Posted on Apr 18, 2011
Pump will not shut off when the sprayer nozzle trigger is releasd on my McCullogh electric press. washer mdl fhh18a
Likely means you now have a leak in the high pressure area. Could it have been frozen over the winter?
Shutoff is pressure activated...
Jun 20, 2015 | McCulloch Garden
Mccullough FHH18A - Looking for connector adapter/ size ?
Why not just purchase a new hose assembly?
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jul 03, 2014 | McCulloch FHH18A Electric Pressure Washer
Turn water on then actuate wand trigger. Pressure washer leaks when wand trigger is actuated and has very low pressure/flow output. After releasing trigger the pressure cycles on - off at approx 1 second...
You gave a very close solution yourself for the problem. But other leakages can cause such symtoms.Forexample a leaking head or a leaking chemical inlet. These can be caused because the spill valve (pressure control valve) is stuck. When this valve stucks it will leave a micro switch ON. So the machine keeps working with the gun closed. This will in turn creat internal pressure and damages the head, valves and chemical non-return and even damage outlet hose. So besides fixing the leakages you must check and service the spill valve. I often replace the spill valve. One must also checks if the micro switch is faulty. Now very important that what you mentioned that the machine cycles at one minute intervals, with trigger closed...this is most probably always the spill valve fault. If you open machine you see a place where there is a wire..this belongs to the micro switch...under you find the spill valve. Intake and suction valves may now also have a fault. Also there are systems with non-return valves at the machine outlet. You have to tackle by elimination. Fix the leakage..then tackle spill valve and micro switch.
Fulltech.
Jul 03, 2010 | Karcher PSI Electric Pressure Washer
Unit is leaking. Just bought it used, runs fine but leaks water out the bottom of the motor. Can this be repaired ? Is there a gasket or o-ring or something to replace ?
it might be the pcv(positive crankcase ventilation) valve. Go to a parts store and ask for a new valve($5-$10) and also ask where it is. It's usually right on top in the back of the engine where you described. If the hose is all cracked then you might have to get a custom one from the dealer because many stores no longer carry hose strong enough to be used here.
May 30, 2010 | McCulloch FHH18A Electric Pressure Washer
Apr 07, 2010 | McCulloch FHH18A Electric Pressure Washer
Water draining out of the bottom of washer
CHECK YOUR WATER INLET VALVES FOR LEAKS BY REMOVING THE TOP OF YOUR FRONT LOAD WASHER. IF LEAKING REPLACETHE PART.
Dec 09, 2009 | LG WM-2277HW Front Load Washer
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine is leaking from bottom of machine
Wow, this washer is very old. im sure the drainage hoses will need to be inspected or replaced asap. i would also check the pump housing for cracks as well. make sure the water inlet valve assembly ins in good condition as well. Replace any hose or valve that is leaking or, damaged.
Jun 05, 2009 | Maytag Washing Machines
Puddle under 1 yr old washing machine hours after it is finished
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
May 19, 2009 | Kenmore 22422 Top Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
McCulloch FHH18A Electric Pressure Washer Logo
103 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
