Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
250 GB Western Digital external HD not detected by Win 98 SE
I am using a small USB cable, about 12 inches (I found out that the long ones will not work with WD harddrive (My Passport Essential) on Win XP. The drive was recognized with XP, but the computer died. I started using an older computer with Win 98 SE. I cannot get Win 98 to detect the WD harddrive. On the WD website, the system requirements are Win 2000, XP or Vista, but also on the website it says you can use Win 98 but only if you install an additional driver. I just can't find the additional driver. I'm looking for a third party driver, but so far no luck. Anybody have any ideas? I would greatly appreciate any help. I have about 144 GB of unusable data (boo). Thanks to anybody who can (or even just tries) to help. John.
  • 1,959 Answers
If you installed SE on Win 98, then here is a link to a generic USB driver that should work with your HD. If at some point you decide to install a newer OS or go dual-boot, you can always partition the HD so you don't lose any storage. Best of luck.
Greg
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Posted on Jun 14, 2009
    President:
  • 1,185 Answers
Go to www.driversguide.com
You may have to fill in a little registration box before you can ask any questions but it is worth it
Once you are on the site type in your question and you will be given a list of options
Dear Sirs, I need the Windows 98 Driver for Western Digital USB External HardDisk 320 GB ? I use COMPAQ Presario with Windows XP to hook up the External Harddisk right know. The External...
Sory to report - from Western Digital support site
Uses SES Drivers
7, Vista, XP
Not Supported
Server 2008, Server 2003, 2000 Server, 2000, ME, 98SE, 98, 95
Win 98 is not a supported OS, for that drive.
Jan 27, 2011 | Western Digital My Passport Essential...
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
I lost the power supply for my WD2500 external HD.
My Book Essentials
12 Volts
3.0 Amps
36 Watts
Sometimes WD will even send you a replacement free of charge, if you give them a call.
Jan 24, 2010 | Western Digital 250GB MyBook External USB...
I formatted the drive and erased all content now i dont have the start up software for it to run when i plug it in
My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
What is the problem? & what to do to get back my necessary files stored in the 500 GB HDD.
Can any one help me, please? URGENT.My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
Jun 27, 2009 | Western Digital 320GB MyBook External USB...
WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
Mar 25, 2009 | Western Digital WD Passport 250GB Portable...
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Win 98
You would need two set of driver:
  • motherboard USB drivers;
  • mass storage driver from Seagate for Win98.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Problem turning on hd
WD = Western Digital , 250Gigabyte external USB drive.
This is where you may need to perform all the USB checks and trouble shooting in the book + load any driver software that came with the drive.
also I would need to know what motherboard and what operating system you are using before I can help farther.
normaly windows 98 and 98 se did was just not able to make proper use of the USB ports , also on nforce2 motherboards service pack2 was required to enable the USB 2.0 feature
we are constantly lied to by the computer industry so get used to it untill the feds crack their skulls.
and remember if it's not hebrew , it's a lie :-> lhime shalom.
Sep 08, 2008 | Western Digital 250GB MyBook External USB...
Win98se i did it ... HERE'S HOW
OK, I bought this Western Digital MyBook 500 GB Essential Edition too, and could not get it to work with Windows 98 SE.
I followed the above instructions, but my version of windows was missing even the drivers suggested above! UGH!
HOWEVER, I found ANOTHER SOLUTION. I installed USB 2.0 drivers for mass storage and the the MY BOOK icon popped up on my Windows 98 SE machine. Hurray! Hurray! Hurray!
Here are the drivers from this british webpage:
Good luck to all you frustrated folks scooping your info off Windows 98 machines!
Dec 29, 2007 | Western Digital My Book Essential Edition...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
1,103 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
