Question about Acer Aspire 9503EWSMi Notebook
Adding additional RAM
I would like to add additional RAM.  Where on the laptop or which cover do I remove to additional 1gb of RAM?
  • 117 Answers
Ddr or ddr2
Posted on Nov 07, 2007
New memory nx6110
Did you remove and replace 1 or 2 RAM modules? There are 2 modules installed. One is internal and one is external. Both MUST BE OF THE SAME DENSITY OR THE LAPTOP WILL NOT WORK. You will need a second 1GB RAM Module, then use the link below to download the service manual for your laptop. Accessing the internal RAM module is fairly easy...follow the directions and you will have not problems. You CAN remove the internal one and operate the device on the single 1GB module, but I would recommend if you do that, you put the 1GB module in the internal slot. Then later, if you wish, you can add more RAM without additional disassembly. By doing this you will at least double your RAM from the 512MB you had to !GB. You can double it again with the second RAM Module to 2GB later.
.GO Here. Find Remove/Replace procedure for Internal Memory Module.
Nov 10, 2013 | HP Compaq nx6110 PC Laptop
How do I install additional ram in a toshiba satelite
There is place under laptop where you add additional Ram.Just remove the bolt and then cover. There are 2 places for Ram.
Mar 19, 2010 | Toshiba Satellite M115-S3094 Notebook
Adding memory to Fujitsu LIfebook Series A3040
You remove the access cover which is where the power button is right under the screen by sliding it to the left until it comes off.Then you push the keyboard up to the back of the laptop until it will lift up exposing another cover. You remove the second cover and that is where the ram is located.Ram is under the keyboard.
Oct 09, 2009 | Fujitsu Siemens LIFEBOOK A3040 PC Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
I want to add RAM to my hp pavilion dv4269us. how do i know how many cards i can add? i want at least 1GB or 2. Is there room for two 1GB cards or room for one 2GB card? What are the best brands? and...
Hi there.
Your system supports 2 GIG (1x GIG each slot)
Have a look here >>>>>>
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=90110
Kingston is one of the best memory modules you can get.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | HP Pavilion dv4000 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Can you add to much Ram for the processor to handle?
    That additional RMA will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
    Jan 13, 2009 | Intel Computers & Internet
    Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
    Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
    Have a nice day!
    Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
    1024 RAM
    You will need to remove the 2-512MB ram that are installed on your computer and buy 2-1GB sticks. There is no other way around this. Download CPU-Z program to find exact memory module needed before you buy the wrong one. Good luck.
    May 19, 2008 | Toshiba Satellite A135-S4527 Notebook
    Acer Aspire 9503EWSMi Notebook Logo
    47 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
