Question about Behringer EUROPOWER EP2500 Amplifier
Our Behringer EUROPOWER EP2500 overheated terribly last night during a gig. We let it cool down and it would work for a few seconds and then clip back out. Channel one was red , while channel 2 was green. Amp is relatively new and we have never had a problem before this. When i touched the amp it was so hot that it almost burnt my hand. We hadn't changed anything and the amps are spread out so they shouldn't be catching a ton of heat from eachother. Any suggestions? We also took the amp case off and didn't find anything.
  • Rommel Cana
    Rommel Cana May 11, 2010
    extract all the audio output transistors of channel one, turn it on, and see the results if the red turns to green , replace all the transistors you just extracted, hope this help, thanks for using fixya!
3 Suggested Answers
  • 5603 Answers
SOURCE: Behringer EP2500 Clip light Channel 2 stays on & heatsink HOT!
There are so many components that can fail that troubleshooting this can be an expensive problem.
HINT: Put a 150 Watt light bulb in series with the power going into to limit current for/during troubleshooting.
Go through and compare the voltages on the teo channels. If power amp transistors have failed, likely the driver transistors also are gone.
Testing components in-circuit is very dificult. Resistors are pretty reliable and usually show damage by discoloration.
Furhter use before repairing MAY cause further damage.
Posted on Jun 04, 2010
Testimonial: "This is just about the most thorough solution I really needed. Which does make my project to fix this amp worth it. Thanks I will try what you say. Thank you."
caroldon
  • 17130 Answers
SOURCE: my behringer europower EP2500 poweramp has a bad
There is a possible noise build up on your CH2 due to failure or weakness of the LCR network of the preamp circuit. It could also be a noise within any semiconducctor or the preamp IC. Unless you can do a signal test with the elimination of the input to the output amplifier, the fault will not be say to isolate. Hence if youarre familiar do the test by approching from the output amplifier's input, proceeding to the main input where the faulty section can be identified. Hope this helps. Good day
Posted on Jul 18, 2010
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
Europower Behringer EP2500, clip lights turn on when main power is off
Depending on the age of the amp,there is a possibilty that the amp my have damaged lanes or tracks to the pre-amp section to the front of the amplifier.
May 29, 2012 | Behringer EUROPOWER EP2500 Amplifier
Clipping the channels
The manual discusses the Clip Inidicator and how to deal with clipping.
Clipping in this amp isprimarily a function of the input signal being distorted so the input level is recommended to be lowered. Beyond that the cause of input distortion would have to be addressed in the device producing it.
http://www.retrevo.com/support/Behringer-EP2500-Amps-manual/id/23281ci655/t/2/
Dec 30, 2010 | Behringer EUROPOWER EP2500 Amplifier
Jun 03, 2010 | Behringer EUROPOWER EP2500 Amplifier
I have a PMP5000, used 5 times now. Last gig I
Cease using it immediately and get it serviced. There are failure modes of this that can do serious damage that requires a lot of work to repair.
If the temp sensors shut it down, it will restore if cooled off... If that doesn't happen service is required.
If just one side of the speakers went out I know exactly what has happened as I have repaired three of these all with same problem. If both sides are down and the rest seems to work, that is an uncommon failure
The cooling fan is throttled as needed and runs only when heat sinks get to a certain temp.
May 30, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Both fuses burnt and both clip and signal led on? seems to have full power behringer ep2500
The fuses have blown due to a short circuit, ie some part acting like it was a piece of wire. The chances are (with the LED's showing) it's the main amp semiconductors (on the heatsink) that have gone. The cause is either connecting a wrong (unsuitable) speaker(s) for the job, or letting the two wires (to each speaker) touch each other.
Mar 28, 2010 | Behringer EUROPOWER EP2500 Amplifier
My clip light stays on behringer ep 2500
DISCONNECT ALL INPUTS(MIC CD) AND CHECK.DISCONNECT ALL OUTPUTS AND CHECK(ALL SPEAKERS ONE BY ONE)IF THE PROBLEM CLEARED WHEN YOU DISCONNECT ANY INPUT OR OUTPUT FIX IT BY CHANGING START WITH CABLES FIRST.
Dec 20, 2009 | Behringer EUROPOWER EP2500 Amplifier
Red light on permanently one 1 channel, that channel just buzzes
on beringer europower ep2500 if both clips lights is on chane d9 d10 d11 d12 and the two 220uf caps for the +15 and -15 voltage supply for the op-amps it a common fault alvan dawkins
Oct 24, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
326 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
