Compaq presario f572 will not turn on
Hello! My f572 is plugged in to 110v, battery installed, and when trying to turn the laptop on the blue power light appears for approx. 2 seconds then goes out without powering up. Any ideas? Thanks!
    Sergeant:
    Champion:
  • 233 Answers
Try with the step Notebook PC intermittenly shut down and reboot with no display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01534678&lc=en&dlc=en&cc=us&rule=34249&product=3441671
Posted on Jun 14, 2009
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
System failure in my laptop ??
Remove the battery from the computer and plug in the correct charger and see if it will power on. without the battery. if so turn off and put battery back in with power connected see if it powers up.
Oct 29, 2007 | HP Compaq Presario 730US Notebook
I have compaq presario f572 notebook laptop. when i plug in AC adapter charging light is turn on but when i press power button its not turn on. anybody can help me............
The laptop is probably charging the battery. I assume you have already tried running this on AC power alone with the battery removed and then on battery power alone? If not try those methods first
Check to hear if the CPU cooling fan is spinning and there are sounds of the hard drive or CD Rom baing accessed. The laptop base should get warm around the heatsink vents after a few minutes too.
If there is CPU and HDD activity, the problem is most likely related to the graphics chip, common on HP / Compaq laptops. This will need a Reball.
If the laptop will physically not turn on and there is no activity as described above, the first thing to look at is the power switch. Remove the switch bezel and see if the power button on the motherboard is sticking or damaged (small contact about the size of a matchhead). Also check if there is a small cutout switch just below the screen near the hinge that is sticking or damaged.
After that, the issue may be the power circuit. Check that the AC adaptor is a tight fit and dis not sloppy, it may still charge the battery but fail to provide power for booting, it will need replaced if sloppy or loose
After that, the issue is likely to be motherboard related and will need a technician to test fully
Mar 31, 2011 | Compaq Computers & Internet
Compaq Presario A900 won't turn on, and battery won't charge (no blue light on when battery charger cord is plugged in.) Any ideas please? Thanks.
The power connector for these Compaqs are notorious for failing when they get a bit grimy. Try wiggling the connector or cleaning it or even gently squeezing with pliers.
Feb 07, 2010 | Computers & Internet
Presario C700 won't turn on after installing new screen
Why was machine taken apart? Did you check memory to make sure it's sitting correctly?
Jan 06, 2010 | HP Compaq Presario C700T
Compaq HP Presario F572US just turned off.
Remove the battery and plug laptop power into the wall (or power strip).
Turn ON laptop without battery.
It should start.
After Windows has settled, put battery back in and let it charge up.
Hope this helps!
Sep 08, 2009 | Compaq Presario F572US Notebook PC
Laptop not powering
try a simple power cycle. Take out the battery, leave power adapter plugged in. Hold down the power button for about one minute. Then hit the power button normally this should correct the problem
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Compaq presario notebook v6128tu won't turn on
You can try to remove that battery and try to turn it on again.
Sometimes this will happen if that don't work the remove the power supply and try to turn it on.
If you see the blue light around the power input then it's obviously getting power but it's redirecting it somehow which brings us to the battery again heh.
Let me know if this does not work
Happy Holidays
Dec 27, 2008 | HP Compaq Presario V6120us Notebook
HP Compaq plugged in & blue light on but icon says NOT plugged in
Check power out put of the adapter is it giving you the correct readings
Try to remove the battery and run it from adapter itself check to see if its working
Reset the battery ..by removing it from the system
Nov 10, 2008 | Compaq Presario Notebook
Compaq Presario F572 Notebook PC
just see any virus is afecting your sytem ..or else try reinstaling windows solves ..it ..
Oct 08, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
50 people viewed this question
Alun Cox
David Payne
David Payne
