Question about Sharp LC-26D43U Television
Hit the reset by accident
Bar at bottom of screen that tells me all the functions that come with the tv, how do I get rid of it
How do I make the screen on my sanyo tv full- It has a black bar top and bottom
Your TV remote control (not the cable box remote control) would have to have a button that would allow the changing of the TV screen sizes. My Sony TV control has a button called, ' wide', and when pressed will change my screen to either, full, wide zoom, and zoom. Only zoom gets rid of the black bars on my TV. If no button, than the screen size will be determined by the broadcaster.
Feb 10, 2013 | Sanyo DP26640 LCD TV
I got a model 27F485 from a bar that closed. Great picture but after a couple minute a black box appears at the bottom of the screen. Looks almost like a PIP but nothing in it. How do I get rid of
Look in the set menu under closed captions, there will likely be a setting there for "TEXT" IF FOUND SWITCH IT TO OFF.
This is a feature a lot of sets had for books etc viewed but was never really used---the result a black box on the screen.
Dec 09, 2012 | Televison & Video
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
How to work viewsonic remote
Hi red recruite,
I am happy to help.
The blue box is the Picture in Picture function. Press the PIP button on remote till gone.
The No Entry Sign on the inputs is because nothing is connected to these inputs.
Unless  I an mistaken you have only a HDMI cable connected.
Let me know if I got it right and please rate this solution. Please keep in mind that Thanks For Trying rateing is negative.
Lone99star
Jan 28, 2009 | ViewSonic NextVision N3260W 32 in....
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Navman S50 Sreies
ok..so..do a firmware reset, and you should be good to go
Mar 22, 2008 | GPS
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Sony tv problem
If you are connecting the dish receiver to the standard antenna jack (F connector) on the TV, then the TV must be in TV mode and tuned to channel 3. If you accidently change to another channel then you will get the "no signal" message. If this is the case then simply put the TV back on channel 3. If you are using the RCA jacks (red, white yellow) to connect the dish receiver to the TV, then the TV must be in the VIDEO mode to work properly. If you accidently put the TV in the TV mode, you will get the "no signal" message. If this is the case then simply press the TV/VIDEO button.
Sep 18, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sharp LC-26D43U Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
