Question about Husqvarna Chain Saw 20" Bar
Replace 18 with 20 inch bar and chain on Model 350 Husqvarnachainsaw as lond as the pitch .325 stays the same?
  • 376 Answers
Yes
Posted on Jun 15, 2009
Husqvarna 450e saw has an H-30 chain with a bar gap of ).050 inches. What is the width of the H-30 chain teeth that run in this bar ?
.325" pitch, .050 gauge. The cutter tooth width is a little wider at the top front, 0.075" and then narrows as it is sharpened down to 0.055"
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Mar 02, 2017 | Husqvarna Garden
Filing angle for Husqvarna chainsaw 450 --20 ' bar chain 72 links?
On .325 pitch chain the top plate angle should be 25 degrees, there is normaly a match mark on top of each cutter, the depth gauge should be set at 25 thousands of an inch.
Apr 02, 2013 | Husqvarna 450 Chain Saw 18 Inch Bar...
What causes the Clutch drum gear that drive the chain to go bad ? my chain eats a groove all the way through it aftr about 12 hrs of cutting I have replaced it 3 times now.
The chain you should be using should be a .325 pitch and not a 3/8.
Never over tighten the chain, it will wear and stretch with time, which is why you should regularly check the chain tension. To get it right you should be able to lift 2 drive links clear of the bar. The chain will naturally wear groves into the spur sprocket, there is no conversion to a rim spricket for this model. Rim sprockets allow the chain to move along the sprocket easier and takes the wear away form the clutch drum.
Oct 11, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Can not find the part number for the Husqvarna Rancher 55 model 967 05 29-00. We need to replace the bar and chain. (18")
In the UK we offered this machine with 13,15,18" bars,.325 pitch 050 gauge, the part no. for the 13" is 508926156, the chain is 501840456, the 15" bar is 508926164 and chain 501840664, the 18" bar is 508926172, and the chain 501840672.
Regards
Sep 11, 2011 | Husqvarna Garden
I have husquavarna chain saw s/n 95212H01984 with sticker that says 41 Air Injection. Need to buy chain and/or chain bar. Need to know the model number for this serial number. Can you provide
The saw is a 41, as standard it ran a 15" bar and chain, in the UK it ran a .325 pitch, however in the US, it ran a 3/8 pitch chain, as you should change the sprocket if fitting a new chain, i would put it on .325 if it is not already, the sprocket is part no. 530069342, the 15" chain is 501840664, and the guide bar is 508926164 these are .325 pitch 050 gauge and 64 drive links, this combination will cut much faster than the 3/8 low profile combination.
May 13, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need to know the degree to set my electric chain saw sharpener for husqvarna chain. This is a 20 inch chain.
A 20" bar unfortunately does not narrow it down. Fortunately both the .325 pitch chain and the 3/8 pitch chain sharpen at 25 degrees and you should have one of these chains. Hope this helps.
Mar 01, 2011 | Husqvarna Chain Saw 20" Bar
Sears craftsman 3.3 cubic inch motor, model # 358356331 chainsaw, what is correct bar length and what is the chain modle and size
According to www.searspartsdirect.com , this saw came with a 20" bar and a .325" pitch, .050" guage, 78 drive links chain.
On sears' website, plug in your model number, go to the handle section and your bar and chain are #130 and #131.
These items are also available aftermarket.
Oregon calls this a #33 or #20 chain, with 78 drive links.
Oregon offers a bar/chain combo part #106874
It is a good idea to inspect the drive teeth on the sprocket of the saw. If they are worn, this is the perfect time to replace the sprocket.
Oct 14, 2010 | Craftsman Garden
After new clutch sprocket &good bar &chain chain r bar moves prematuely and chain comes off bar nuts r tight
have you made sure that chain pitch and gauge are the same as the sprocket pitch pitches can be 3/8 lo pro 0.50 gauge
.325 x 0.50 gauge , .325 x 0.58 gauge
3/8 std x 0.50 or 3/8 x 0.58 gauge or 3/8 x 0.63 gauge
you could even have the correct drum but wrong rim sprocket on it
worst case is you could have mismatch bar and chain
make sure that bar adjjuster assy is working correctly
recheck chain / sprocket pitches and bar pitch and groove
gauge
be sure that you fitted chain to rim on sprocket correctly when you fitted bar and chain?
is the clutch cover pulling down tight ?
have a look and let me know if and what you find
cheers paul
Aug 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
HUSQVARNA MODEL 50 BAR AND CHAIN UPGRADE
I have a nearly worn out 42 cc Husquvarna that uses a 20 inch bar very successfully. With proper filing of the chain you should be able to run a 22 inch bar very well. Ensure that the roller nose on your new bar matches the pitch of the clutch sprocket that you are using at present. If not, have your chain saw shop change them so they match.
I would advise that you change the bar and sprocket to use a .375 chain as this will be easier to sharpen successfully than the .325 pitch chain you might be presently using.
I am six feet tall and short bars are murder on my back so this is why I use no shorter than 20 inch bars on my saws.
Jan 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
141 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
