Question about Pets - Others
Scoozie pet instructions
There appears to be two ends that have a screw and should maybe have a battery for my scoozie pet but what kind and where exactly do they go?
Changed the battery in our Scoozie and do not know what to push or pull to make it work?
'Scoozie' gives no clues at all, even Google doesn't know. For vehicles, we need year, make and model. A good description of what is wrong and what you have done.
Scoozie Google Search
Mar 19, 2017 | Cars & Trucks
I have model#UD40350 total pet compact. The lower vacuum brushes don.t turn.
Hi! It sounds like you have a broken or stretched belt. The belt controls the brush roll. If you are using the vacuum on carpet, you need the brushes to spin to agitate the carpet fibers. Below are step-by-step instructions on how to replace your belt. I have also included a link to the instruction manual if needed.
1. Lay cleaner flat and flip to expose nozzle base. To remove nozzle guard, use Phillips screwdriver to remove the screws.
2. Lift and remove brush roll and dispose of old belt if you see one.
3. Slide belt (style 19) onto motor shaft.
4. Place new belt on area of brush roll without bristles.
5. With new belt in place, pull and slide brush roll into nozzle making sure that the brush roll end caps are in the correct orientation.
6. Replace all screws to replace nozzle guard.
http://dirtdevil.com/file/898/
Hope this was helpful!
May 06, 2014 | Dirt Devil Dynamo Pet Bagless Upright...
Where can i get the end part that screws into the wall?
here is the phone number Carlson Pet Products 952-435-1084.
Mar 28, 2014 | Top Paw Extra Tall Pet Gate with Small Pet...
My wahl chromado clippers will not hold a charge
Click the blade off, inside the front end there should be 2 screws, undo them and force the case halves apart from the front. Battery pack will need to come from Wahl, not normally available as a non genuine part.
Nov 01, 2012 | Wahl Chromado Professional Cord/cordless...
Good afternoon, I search a french instructions for Micro Pets tomy "Gork " Serie 2 U.S . I have forget my instructions list :/ Please help me. Thank you
If you have a brand-new MicroPet, remove the"Try Me" plastic strip before using the pet.Turn the MicroPet over and locate the plastic strip protruding from the batterycover; pull the strip straight out.
    • 2
Change the batteriesif the power is running low -- the included batteries are used for testing andmay not be fully charged. Turn the MicroPet over and use a Phillips-headscrewdriver to remove the screw at the top of the battery cover. Slide thebattery cover out and remove the old batteries. Insert two LR44 batteries,making sure to match the polarity as instructed. Replace the battery cover andtighten the screw with the screwdriver.
    • 3
Wake up your MicroPet by pressing the button onits head; it will perform an action to let you know it is awake. Say a phraseto your MicroPet, then wait for its nose or tie to light up. Now say a secondphrase and the MicroPet will follow your command. For example, say,"Robo," then wait for the pet's nose to light up, then say,"Run," and the MicroPet will run.
    • 4
MicroPets display two "moods,""happy" and "bad," depending on the commands it receives.If you repeat the same command over and over, your MicroPet will display a"bad" mood. It will then refuse to listen to your commands and willnot respond to you. Praise yourpetto cheer it up and make it happy. For example, say, "Good job," toyour MicroPet.
    • 5
Press the button on top of the pet's head while itis performing a command to reset the MicroPet.
    • 6
Hold down the button on the top of your MicroPet'shead for three seconds to make it go to sleep; it will sing a goodbye songbefore shutting down.
    • 7
Make your MicroPet sing one of three songs byclapping your hands. Clap three times for "It's a Small World," fourtimes for "Ten Little Indians" and five times for "ElectricalParade." Make sure to wait for the pet's nose to light up between eachclap. Place multiple MicroPets together and they will sing in unison.
    • 8
To program your MicroPet, turn the MicroPet off,then press the button on top of its head six times --- the pet will light up,then make three small beeping noises. Wait one second and the pet will light up--- press the pet's head button now if you want to program the "GoForward" command. To program the "Turn Right" command, wait forthe pet to light up twice, then press the head button. To program the"Turn Left" command, wait for the pet to light up three times, thenpress the head button. When you hear three beeping sounds, the MicroPet isfinished programming and will perform the commands. You can program up to fivecommands in a row. When in program mode, your pet will not respond to your voicecommands or sing songs. To go back to the normal command mode, simply turn theMicroPet off then back on.
Feb 18, 2011 | Tomy Micropets Tomy - Kuda. Magic voice...
Batteries are stuck in the flashlight. How do I get them out without distroying it?
If they are stuck, they have probably leaked and the flashlight is probably corroded already. But here are two suggestions. Get a heavy piece of string and tie it securely around the flashlight at the lens end. Tape it on with duct tape for good measure. When hung by the string the lens end of the flashlight should point up and the open end should point down. Stand in a place with lots of space and no windows or pets or people around. Swing the string over your head to generate some g's. The batteries may come flying out. Another suggestion is to drill a hole in the battery, put a long screw in it and pull it out. Wear safety goggles. If the second battery is also stuck you will need a long drill and a longer screw. Good luck.
Nov 29, 2010 | MagLite Mag LiteĀ® 2x 'd' Battery ...
How do I change the belt on Eureka Pet Pal
Unlike most vacuums, this one the screws are on the top of your base. There are two screws one on each side. When looking at the front of the vacuum right side screw is located above the s in 12amps and on the left side screw is located above the p in pet. Now keep in mind it's not directly above the letters look about 2 inches up. Unscrew them, take cover off. Once you have done that pull up on the brush rod. Maybe tough if ur vacuum has a lot of built up dirt. Next put belt on metal prong then put on brush rod. Place rod back in its spot, gonna need little bit of muscle. Then put top back on and replace screws. Plug in flip bottom just to make sure brush is spinning. If u have followed steps this should work. I hope this helped took me forever to find the screws because I have always had vacuum with them on the bottom and internet was no help to me. Good luck
Nov 25, 2010 | Eureka 3276AZ Pet Lover Bagless Upright...
How can I remove the pet hair that is trapped in the initial vacuum assembly? I don't see screws for removing the clear plastic panel
Generic comment.
If the parts aren't glued in, they must be snapped in or fastened with screws. You say there are no screws - try unsnapping.
I think id try a coat hanger first with the help of air pressure if you have access or a second vacuum.
Pet hair is definitely an annoyance in these machines. I know from experience. I guess that is why the instructions generally say to vacuum first! I learned my lesson with the coat hanger/air/vacuum method. Who needs stupid instructions anyway!
I hope you get your machine unclogged.
a
Oct 04, 2009 | Hoover F5870-900 SteamVac Vacuum
Need to know how to put batteries on cosmic catch
there is a small screw right on the ball..in a square of foam on the ball itself. batteries are to go inside the ball. hope this helps!
Jan 11, 2009 | Cosmic Pet Hasbro Cosmic Catch Game
Pets - Others Logo
132 people viewed this question
Top Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Pets - Other Expert? Answer questions, earn points and help others
