Question about Fisher and Paykel Washing Machines
Fisher and Paykel MW512. Error Code can't be determined. Light 8 flashes as does lid lock light
Hiya, I have a Fisher and Paykel MW512. I can't work out the Error Code from the various manuals online. Light 8 flashes as does the lid lock light. There's a bit of a clunk from the lock function? Any ideas?
  • Lana Habs
    Lana Habs Mar 23, 2014
    Number 8 (spin cycle) and the light above 'on/off' switch. Also labelled 'lid locked'.
    Sergeant:
  • 223 Answers
Exactly which lights are flashing?
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/420983_Smartdrive_UC_UD1.pdf
Posted on Mar 22, 2014
issy2
  • 462 Answers
SOURCE: Fisher and paykel washing machine.
hello... removing the board of ur washing machine is going to be a little tedious.. but if ur used to such opening up circuits then fine... have a dry cloth in hand to clean water droplets and also wear a rubber slipper to prevent shock.. examine the board may be if u have a plug in sockets try to remove and reinsert them provided u clean the contacts too.. and try it ON again..
Posted on Aug 05, 2008
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 41 Answers
SOURCE: MW512 filling in spurts then goes to error.
it nneds a new Outer blance switch , cheap nd easy to fix
Posted on Jan 31, 2010
NZcavalcader
  • 83 Answers
SOURCE: fisher & paykel machine locked but lid is up
select the spin cycle and press start/pause, put a small magnet along the right side, top, approx 2 inches from the front to trick the lid switch (move the magnet forward/aft until the machine starts working). Let it complete the cycle, then try to colse the lid completly.
Posted on Sep 05, 2010
  • 6 Answers
SOURCE: RE: fisher & Paykel top loader ecosmart DWL11
http://fisherpaykelparts.net/techhelp/index.php Give this website a try, it worked for me!
Posted on Dec 27, 2010
Drying and Lid Locked lights flash red and it beeps continuously. Dryer will not start.
look on coolblueworld.com or paperwork for error code is in back consol . please unplug dryer if you remove consol.
Mar 21, 2015 | Fisher and Paykel SMARTLOAD DE62TG1...
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
Gw612 error code lights
the motor controller needs replacing. this fault is not servicable at home.
Sep 07, 2013 | Fisher and Paykel Fisher & Paykel Washer
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
Mw512 beeps and wont start
The lid switch sounds logical. That would certainly halt the cycle. I'm not sure what actuates the lid switch on your particular model but check it as well. Good luck.
Jan 13, 2013 | Fisher and Paykel Washing Machines
Hi I have a gw612 Fyscher and Paykel 8 years old. It is now refusing to start and the led lights when I turn it on are the third and the fourth wash cycle lights as well as the spin light. If I press start...
Hi just read your posting.Starting from the left to right if the lights that are on when the machine is beeping are the 3rd and 4th and 8th then the error code is called COLD VALVE FAULTY.This means either your cold water valve is faulty or you control module is faulty.Would you like me to guide you in the testing and isolating the fault and replacing the faulty component?Please reply for further help.Looking forward to your reply.
Oct 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Jan 23, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel GW612 beeps before spin.
You have fault code 66 (01000010) Phase 6- Pressure Transducer (Ptx) Error - Frequency >90kHZ. In simple terms you need to replace the main "Motor Control Module" Cheers
Mar 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
399 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
