Question about Fisher Washing Machines
Fischer paykel c09
I have a fisher paykel smart drive c09. Does anyone know how to clean it, as there are black stuff coming out during the washing cycle and stick on my clothes. There's a top lid I can take out from the middle pole but I can't remove anything else to clean. Anyone know how to do it? Thanks!
    Scholar:
  • 77 Answers
The black stuff is called "Scrud".
It builds up over time from a combination of washing detergent and fabric softener.
Reach your hand down the middle of the agitator (middle pole) after removing the cap. There is a plastic wing nut that you can undo with your hand. The agitator can then be lifted out.
The other easy solution is dumping half a box of epsom salts in there (usually in the bath/ medical isle of the supermarket), run the machine empty, on HOT, Full load so that it fills all the way. Usually this cleans most of it out.
A more regular empty hot wash will prevent build up in the future.
Posted on Mar 22, 2014
IFIXALL
  • 868 Answers
SOURCE: Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Posted on Jun 08, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
SOURCE: We have a Fisher & Paykel Smart Drive 9
Thank you to the gentleman who sent us the Manual.  We now know that F & P has an automatic Lint Filter which is pretty useless !!  Oh, for the old method of a physical filter you can clean...
Posted on Sep 13, 2009
  • 41 Answers
SOURCE: Fisher & Paykel washing machine model- smart drive 603
prss and hold the fav button till u hear 2 beeps , set whatever u want it to be and then prss and hold the button till u hear 1 beep turn power off , set
Posted on Oct 27, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
Unable to wash using hot water -F & P Smart Drive 608 (GW608U)
Check that the valve behind the washer for the hot water is open, it will be labeled red and should indicate which way to turn to open it typically counterclockwise.
Dec 17, 2011 | Fisher and Paykel Fisher & Paykel Washer
I have a Fischer Paykel Smart Drive 5.5 which is leaking water into the machine when it is switched off. Obviously when I turn off the feeding taps the water stops dripping but how can I stop the leaking...
(pre-typed to cover hot and/or cold!)
This is symptomatic of a malfunctioning (not closing completely) water control valve
With power off, if it is hot AND cold fill, turn one or the other off and see which one is causing the problem. Sorry but it needs replacing and a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 17, 2011 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Is there a filter on the smart drive 051- my washing is coming out with dirty black marks
if the black marks come out then it is lint. put 2 pkts bicarb soda into empty bowl, select hot fill, select high water, start cycle. let it wash for 10 min"s , turn machine off, leave overnight. restart cycle in the morning, that should clean tank and bowl. please reply 4 more help.
Apr 23, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Problems with fischer paykel self cleaning oven
Hi and welcome to FixYA.com!
Here are links to the two most popular Fisher Paykel Wall Ovens:
OD/OS301:
http://www.fisherpaykelparts.net/partmanuals/545619C_Aerotech_UGM_USw1.pdf
OD/OS302:
http://fisherpaykelparts.net/partmanuals/599194C_Aerotech_ugm_USw.pdf
If neither od these is your model, let me know which one you have and I will locate a use and care guide for you.
Hope this helps and Happy Holidays from the FixYa crew!
Dec 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
Mar 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel washing machine fault codes
Mar 12, 2008 | Washing Machines
Washing Machines Logo
81 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
