Question about Vehicle Parts & Accessories
How do you put pushrods back in a 98 v6 3100 grand am gt?
I need to know how to put the pushrods back in on my car I didn't keep them order as they came out
    Master:
  • 710 Answers
MNeasure and make sure they are all the same. If they are no worries.
Posted on Sep 01, 2014
Firing order diagram for 1998 jeep cherokee 5.9
Talynn Wright wants answers to this question , off 2012 post
ok , so you removed spark wires. and didnt mark the,
or replace them 1by1, at a time
oops.....
why not read this is the spark chapter, the real book is free.
seen here.
XJ jeep is non grand jeep , uSA
but wait ther eis no 5.9 in a XJ, so you hyghJACKED the wrong post., yoiu have grand Cherokee , why not start your one post
with real name of car and year.
98 grand
5.2L and 5.9L are same for spark
knowing only the firing order is only 1 of 3 things needed
to put the wire back . right
click ZJ (chapter 8d,p24) read
here
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
May 22, 2012 | Jeep Grand Cherokee Cars & Trucks
I have replaced the heads on a2000 grand am Gt after having them shaved and tested and after putting the rocker arms back on the engine will not turn by hand is something misaligned
hi, i have very good experience with these engines, 3.4 litre v-6 right? these engines use two different length pushrods, long on the exhaust, short on the intake valves. there was a time when i did not know this fact(when i was just learning as a mechanic) and i swapped a couple of them. when i went to fire the engine, the valves hit the pistons on the intake side and locked up the engine, bent the rods and valves. this maybe what happened? but these engines have very close tolorance valvetrains, if you have not swapped the push rods by mistake, you speak of heads being shaved, there was one engine that i put the heads back on after being serviced by the machine shop and they had shaved too much off of the heads and the pushrods hit the pistons anyways. one more thing that happens, if coolant is left in the cylinders when the heads are put back on, or if it gets in the cylinders by accident, it will "hydro-lock" the engine. water cannot be compressed as air and atomized fuel can be. check to see if it will turn one way, but not the other at a certain point,(clockwise and counter) if it does, this may have occured. hope it is just coolant, you will only have to remove the spark plugs and crank the engine to relieve the coolant from the engine, then re-install the plugs. but if the pushrods are incorrectly installed, or the valves hit due to shaved heads, you will get to remove heads again to inspect.
Jun 25, 2010 | 2000 Pontiac Grand Am GT
My car doesn't want to staart it just keeps turning over and over like its not getting any spark i forgot the firing order so i think thats the problem hopefully or something simple what else could it be...
I do not know if you have the 2.4L or 3.4L Engine; however I have included both below.
For the 2.4L:
Firing Order:
1-3-4-2
Cylinders:
.....(back)
1....2.....3....4
.....(front)
For the 3.4L:
Firing Order:
1-2-3-4-5-6
Cylinders:
(back)
2..........1
4..........3
6..........5
Ignition Coil Connections:
............(back)
..|.5..2.|.|.3..6.|.|.4..1.|
............(front)
Let me know if this helped or if you have addtional information of questions. Feel Free to contact me at Fix Ya.Com!
Mar 16, 2010 | 2000 Pontiac Grand Am GT
How do i remove the stock intake box from my grand prix gt
Look for attachment bolts inside the air box under the filter at the bottom. ducts usually pull right out, just watch that you don't break or damage wiring etc.
Oct 19, 2009 | 1998 Pontiac Grand Prix
It is a 1998 pontaic grand prix GT. and would like to know the number order for six sparks wires to put back on engine from front to back
Hello! Here is the firing order for that vehicle:
Front side (L to R) : 1 - 3 - 5
Rear side (L to R) : 2 - 4 - 6
Thanks for using FixYa!
Sep 27, 2009 | 2000 Pontiac Grand Prix
Pushrod order
long ones are the exh shorter ones are the intake
Aug 25, 2009 | 1997 Pontiac Grand Prix
No fire to coil from coil on 96 model Jeep Grand Cherokee.
You need to put the harmonic balance for the 96 jeep on this motor,then put the crankshaft sensor on for the 96 jeep on the vehicle,this should fix you up.The crankshaft sensor and the harmonic balance have to go together.If I can be further help,let me know.>>roniecon@gmail.com
Aug 18, 2009 | 1996 Jeep Grand Cherokee
Will a GM 60 degree V6 work in my '97 Rodeo LS V6 4wd
NO! Call a salvage yard, they have info. on what will fit it.
Jun 04, 2009 | 1995 Isuzu Rodeo
Misffire 1 & 2 detected multiple cylinder
the coil pack it's self should be numbered Starting left to right across the front it is 2, 4, 6 and across the back left to right it is 1, 3, 5. Emissonwiz (only the OHV, pushrod V6 was avaliable in 99 unless you had the 4 cylinder)
Nov 05, 2008 | 2000 Pontiac Grand Am GT
Vehicle Parts & Accessories Logo
18 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
