Question about Hotpoint Ultima WF860 Front Load Washer
I have a hotpiont wf860 flashing fault code H20, please help
I have a hotpoint wf860 flashing fault code H20, please help
  • 75 Answers
H20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Posted on Aug 02, 2009
Malcg
  • 32 Answers
SOURCE: hotpoint ultima wf860
Manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HB00503_WF840_860_865_19504206802_jan05.pdf
There is a helpline number listed near the end to give you further help
Posted on Apr 13, 2008
  • 239 Answers
SOURCE: FAULT CODE F-03 ON HOTPOINT WASHING MACHINE WF860
i believe that has to do with thermostat circuit. bad thermostat or wiring
Posted on Apr 18, 2010
  • 1294 Answers
SOURCE: WF860 error code
Click on your model numbers (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. You might find the mysterious codes there.
And dont forget to rate me on this great site.
Posted on Jan 17, 2008
  • 4 Answers
SOURCE: Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Posted on Apr 17, 2009
barkencoa
  • 3463 Answers
SOURCE: h20 fault is flashing on my hotpoint washing
H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose/s.
To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, thjn the valve will not operate properly..
If you are satisfied it is o/k then it is quite likely a valve fault, also check the filter built into the valve inlet.
Posted on Dec 08, 2009
My washing machine flashes H20
Try to put some hot water and drain it(not too hot)
Apr 08, 2014 | Hotpoint Ultima WF860 Front Load Washer
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hi i got hotpoint ultima igot flashing h20 on screen
These are the notes I have-
Providing it is not in demo mode, H20 means 'no water is being supplied'.
Press and hold 'start/cancel', release then press again to cancel the drain. The machine should now be reset.
If H20 returns there is a problem with the water supply- the hoses are kinked or squashed, the taps are not turned on fully or the water inlet valve is malfunctioning, apparently!
Good luck,
John C
Mar 11, 2011 | Hotpoint Ultima WF860 Front Load Washer
Machine keeps beeping. Filling and emptying with water and H20 is flashing in the digital display
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments for more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
I HAVE A HOTPIONT WF860 WITH NO MANUAL CAN YOU HELP
Hi pinchin007,
Got your manual here:
http://www.manualsmania.com/download.php?link=9622dbd8494c475892f1ebfe151482efc014c
Regards
R.K.
Oct 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultimasimply flashes H20.
witch one of theses are your washing machine?
lcd evo01
lcd evo02
or the V4
please let me know so i can get you the right term for the code.
Aug 14, 2008 | Hotpoint Ultima WF860 Front Load Washer
WR480 ERROR CODE H20
h20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
May 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
WF860 error code
Nov 10, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
2,297 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
