Question about Necchi 4595 Mechanical Sewing Machine
How to thread bobbin
How do I thread the bobbin correctly? The bobbin thread is too loose
Bobbin stitch is loose. can be pulled out
When the bottom stitches are loose it usually means the machine isn't threaded correctly. Un thread the machine and take the bobbin out. Rethread the top making sure the thread is in the tension slots securely. Replace the bobbin making sure it is inserted correctly. You might also need to replace the needle.
Jul 02, 2017 | Sewing Machines
Bernina activa 130 tension loose after needle breaking into bobbin area
Is it the bobbin tension that is very loose? Try tightening it. Also check that the bobbin has been installed in the bobbin case, turning the correct direction and that the bobbin tension is threaded properly.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
If it is the upper tension that is loose and creating "thread nests" under the fabric, the machine is either misthreaded or possibly the thread is not seated completely in the tension disk.
Remove the upper thread from the machine.
ALWAYS RAISE the presser foot and rethread the upper thread from the beginning--verify the thread path is correct.
Set the upper tension to the midway point between high & low number (the factory standard--although it may need tweaking later for your particular machine).
Retest your machine. Hopefully, the issue has been resolved. If not, it may need service.
Tutorials Urban Threads Unique and Awesome Embroidery Designs
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Oct 03, 2016 | Bernina Activa 130
Why does the bottom tread come out loose and loopy
First, check the stitching to verify that it is in fact the bobbin thread that is loose & loopy. Usually, loopy thread under the fabric is the upper thread--which, if that is the case, is an indication it is either threaded incorrectly or the upper tension is too loose.
Make sure you are using a brand-new needle.
Always RAISE the presser foot and then thread the upper thread making sure that every guide and the correct path is followed.
Set the upper tension to the midway point between high & low number and re-test the stitching. Re-adjust as needed. The tension is correct when both upper and bobbin threads meet in the middle of the fabric.
If it is in fact the bobbin thread causing looping, it could be that the bobbin case is not threaded properly or the tension is way off.
Liz Kettle adjusting your bobbin case tension 1 wmv
Apr 11, 2016 | Sewing Machines
What makes the stitches loose? How do I make them tight?
You should have a tension knob (1 to 10) on the machine, the lower the number the tighter the tension.
Jan 09, 2016 | Sewing Machines
The upper thread is too loose and the bobbin thread is taken up too much
It is the upper thread which pulls the bobbin thread up. If the bobbin thread is taken up to much, one solution is to loosen the upper thread -- but the upper thread is too loose. Therefore, the same problem needs to be combated from the bobbin side.
The thread from the bobbin should slide through a wedge. On that wedge should be a screw. It needs tightened. The bobbin thread should be tight as follows:
A fully loaded bobbin should tangle by the thread without falling. While dangling the bobbin by the thread, bounce the bobbin (yo-yo style). An easy tug should cause the bobbin to release an inch or two of thread and then the bobbin should stop falling on its own.
Once the bobbin tensioner is correct, you should be able to tighten the upper tensioner.
Jun 02, 2011 | Singer 5050 Mechanical Sewing Machine
Bottom thread too loose; tried rethreading top thread, cleaning bobbin case, refilling bobbin, changing needle, adjusting top tension
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Dec 18, 2010 | SINGER 7470 Sewing Machine
Bobbin thread is breaking and thread is knotting up on the underside
check the bobbin case tension--turn the screw to the left to tighten ---turn the screw to the right to loosen
also check the needle to see if it's damaged
also make sure the bobbin is threaded correctly & placed correctly in bobbin case
check for lint or loose threads in bobbin area
check for warped bobbin
Sep 27, 2010 | Kenmore 756A-30BH Mechanical Sewing...
I am using a satin stitch to applique. The tension is incorrect. I have placed a different colour thread in the top and bobbin, the top thread is appearing only as a single thread through the bottom...
You need to tighten the tension on the bobbin thread as it is too loose and is being pulled through by the tension on the top which is probably correct. First check that the bobbin is in correct. I know it's frustrating but even after 40 yr it's where I start if it's all in right then tighten the screw on the bobbin case a little at a time till you get it to the right tension. The thread coming out of the bobbin case should take a pull for thread to come out if you hold the thread and turn loose of the bobbin case and the thread unwinds like a yo-yo it's to loose. The bobbin should stay in the case wile you test it this way.
Apr 07, 2017 | Brother XR-65t Mechanical Sewing Machine
Bobbin won't wind correctly!!
Iam very picky about my bobbins!
make sure you are threading the machine for the bobbin correctly, In my opinion I don't think any machine really winds well.
What I do is hold the thread about an 1" away from the bobbin. start to wind and I guide the thread slowly up and down the bobbin so that it winds even
Aug 28, 2009 | White Sewing 2200 Multi-Tasker
Elna supermatic bobbin and threading instructions
Check out these instructions and diagram. Good luck. Paste this link to your Address bar... http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
Sep 09, 2007 | Sewing Machines
Necchi 4595 Mechanical Sewing Machine Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
