Question about Safety First Power Strip
Whining sound coming from power strip
Sound from power strip
What can cause a whining noise coming from 2003 mazda 6 engine?
That is commonly caused by a power steering pump issue, it is either low on fluid due to a leak in a hose or the pump is defective.
Oct 06, 2016 | Mazda Cars & Trucks
The amp gets power, however the speaker emits a constant whining sound
Sounds like the output capacitors are breaking down, or you have a faulty pickup causing feedback, this can also be caused by bad cables close to ac power causes hum and distortion.
Jun 18, 2015 | AMP Music
Duratec ford whining sound
Most whining sounds come from the belt area and are caused by a bad bearing in a pulley. You can remove the belt and start the car to see if the noise goes away. If it does, you need to spin all the pulleys by hand to check for roughness/looseness.
May 17, 2015 | 2008 Mercury Mariner
Whining while braking at low speed
it is possible the brake pads are worn to the indicators which is a small metal strip designed to squeal thus giving a warning
Feb 26, 2014 | Cars & Trucks
Whining sound gmc yukon
The best way to find noise is a thesescope can get at automotive store put on each component and listen for noise To me I know you said new alternator but sound like the rectifier in alt disconnect the alt wireing and listen also check the idler pulley bearings Dose the truck have AC Take the AC belt of and try it as its a seperate belt
Jun 14, 2013 | Vehicle Parts & Accessories
Whining sound comeing from engine
It maybe the problem of V8 6.5 turbo diesel. To use the turbo success, the car must be reached the high certain speed. So it maybe the normal that whining sound coming from engine. Diagnostic engine regularly.
Oct 26, 2012 | Chevrolet Cars & Trucks
The power steering is making a whining sound, what
add power sterring fluid asap, and hope that it fixes it, otherwise time for a new power steering pump.
Dec 30, 2009 | 1999 Ford Windstar
Whining noise when turning left seems to go away after vehicle warms up. limited quadra trac
Does the whining sound like it's coming from the power steering? This usually is an indication that the power steering fluid level is low.
Oct 21, 2009 | 1999 Jeep Grand Cherokee
Whining sound from under van only when i push the gas.
The serpentine belt is the most common cause for whining sound when accelerating, try to understand if noise is coming from serpentine belt.
Also check power steering belt under steering column, and also the rotor and chain, thei do not make whining noise , but can make noise when accelerating.
The belt is first suspect.
Mar 26, 2009 | 1988 Chevrolet G20
Safety First Power Strip Logo
431 people viewed this question
Top Safety First Electronics - Others Experts
Are you a Safety First Electronics - Other Expert? Answer questions, earn points and help others
