Question about Frigidaire Dishwashers
No start Lights blink
  • 14 Answers
There is a control board behind the front cover, remove 6 large round screws, pull handle and cover comes off, see small cover, board is in there, take board off, turn board over,,, look closely and see if part of the board is discolored, this is really the only power/control there is anyways,,, so get one from Sears or wherever,,, it is about 160.00 but it should work,,, first try shutting off the circuit breaker for the dishwasher to reset if possilble, and don't forget before removing the board to shut it off too. good luck
Posted on Mar 22, 2014
Buttons on the dishwasher's control panel is not working. When starting a "normal" load, it switches to "clean" and does not start the wash.
Hello. Most likely, the humming sound you hear is a jammed drain pump which is activated immediately to pump out any stale or standing water below the level which you can see. Then, fresh, hot water enters the tub to start washing the dishes. I need the model number and exactly what lights are blinking--those blinking lights are error codes(combinations of 2 or more lights, one light blinking a certain number of times, then blinking again, a different number of times--ex 3 times, then 7 times) the lights blink a binary error code--thats why I need the model number to look up the code on the chart
Sep 10, 2015 | KitchenAid Dishwashers
Toyota Echo 2003 SRS light with ABS light blinking instead of Seat Belt Light
When you sit in the seat and put the seat belt on does everything work ok . If so look to the fact that you are required to wear a seat belt and the fact that you are not might be the problem.
Mar 09, 2014 | Cars & Trucks
Blinking lights
You say the "FORNT" lights blink and the system "Wont" start?
That is because the Hard Drive is not functional, or the Operating System is dysfunctional. Reinstall Windows... no other choices. If you can not install Windows, the drive is bad.
Dec 08, 2013 | Dell Precision 490 Workstation Xeon...
Lights Blink washer wont start
Check user manual for programme reset , but poss. hold start button on for minute or try same with cancel button.
Nov 02, 2009 | Washing Machines
Cycle lights blinking and dishwasher will not start.
The touch pad is shorted and needs to be replaced..
Jan 19, 2009 | Dishwashers
Two blinking lights on top
lights on my asko dishwasher start blinking into the cycle
Nov 18, 2008 | Dishwashers
Blinking lights
I left if off and unplugged for a few hours. When I plugged it in it started working again. My recommendation if this happens to you is to just unplug it all and let it stand for at least 4 hours and then plug it back in.
Good Luck
Oct 01, 2008 | Sony RDR-VX555
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
37 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
