Question about Centrios Wrist Strap Blood Pressure Monitor
It inflates a little then it shuts off and shows E1
It just not inflating enough
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
How to inflate pneumatic tires?
You will probably find that they are infil tyres which are classed as solid, so they can not be inflated, your problem will lie elsewhere,ie :- something rubbing against the tyres.
Apr 03, 2014 | Pride Health & Beauty
Tv turns off itself
When it have this kind of error is a problem of the power-board.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
Mar 19, 2014 | LG 60PK550C - 60in plasma TV
Sphygmomanometer
I take it the device is either auto or manual. If it uses batteries, they may be exhausted. Or, there is a valve that may be open. It looks like a shiny metal thing near the bulb. Or that valve might be defective, and it just doesn't shut properly. If that's the case, it should hiss a little bit.
The hose might not be screwed together tightly. There are inexpensive, accurate wrist cuffs for blood-pressure monitoring that work very well. If none of this works, you might pick up one of those.
Jan 20, 2014 | Health & Beauty
I am trying to inflate flat tire and can't get it to inflate with air master air compressor 59008. what am I doing wrong?
Jack the car up on the side you want to inflate to get the weight off of it. No compressor that i know of that plugs into a cigarette lighter is strong enough to inflate a flat tire under that much weight.
Nov 01, 2012 | Mini Tools & Hardware - Others
E1 error
E1 indicates an air circuit abnormality. Wait one minute and try inflating the cuff again. If the problem continues, contact HoMedics' Customer Support 1-800-466-3342.
Hope this helped and thanks for choosing FixYa.
Aug 25, 2011 | Walgreens By Homedics Automatic Blood...
Rear air bag shock inflate to much
Mine were not inflating enough, if yours are inflating too much at least you know the compressor is working. Possibly only needs minor adjustment like mine. My mechanic only charged me $30 bucks to adjust system.(local mechanic, not a dealership)
Good luck
Dec 11, 2009 | 2002 Oldsmobile Bravada
Gemmy inflatable band light show 10ft
Is the fuse inside the sound box .. does it look like the fuse in the end of the plug .. Thanks
Dec 02, 2009 | Gemmy Inflatable Polar Bear on Motorcycle
From what is an Inflatable Towable made of?
AN INFLATABLE WATER TUBE IS GENERALLY CONSTRUCTED FROM AN ENCLOSED FLEXIBLE PVC RUBBER BLADDER AND SURROUNDED BY A NYLON FABRIC COVER. MOST TUBES CONTAIN A VALVE THAT ALLOWS THE RIDER TO INFLATE THE TUBE MANUALLY OR BY WAY OF AN AIR PUMP. RIDERS SHOULD LOOK FOR TUBES THAT HAVE ENOUGH HANDLES TO ALLOW THE RIDERS TO SAFELY AND COMFORTABLEY RIDE.
Dec 01, 2008 | 3M SportsStuff Speedzone 3 Inflatable...
Centrios Wrist Strap Blood Pressure Monitor Logo
Top Centrios Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Centrios Health and Beauty Expert? Answer questions, earn points and help others
