Question about Sony FD Trinitron WEGA KV-27FV17 27" TV
Turns off.sometimes it works fine .then it just turn off ?
After turning on my my acer 2300 its boots up fine but the fan only works for a few seconds then stops and then does not work at all
Normally if the fan is bad and failing the laptop will run hot (overheat) and shut down. If yours is not doing that, then you are fine. Sometimes the fans will turn on and off as needed.
Apr 01, 2012 | Acer TravelMate 2300 Notebook
2003 Ford Explorer Sport rear turn signal acting up
if it's only the rear turn signal that does this, check the plug where the bulb snaps in. if loose or bad connection to bulb, it will sometimes work and sometimes not. if its both the front and rear turn signal bulbs, could be the combination switch. these were common failures on fords
Feb 18, 2010 | 2003 Ford Explorer Sport
Sometimes when I try to copy from the glass the display says "warming up" then "scanner faiure" then turn off and on. I turn it off then uplug it, plut it back in and turn it on.. sometimes it works...
I am glad it will still print. Your problems as described are most likely caused by a faulty scanner bulb. One fine day, it probably will not work at all. Sorry about that!
Dec 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
Computer not recognizing video card maybe?
If you have a onboard graphics on your mobo they may have been turned on somehow I would check there and disable them if they have been.
Aug 15, 2009 | ASUS Extreme AX800XL Radeon X800XL, (256...
Left turn signal
sounds like it needs a turn signal switch
Apr 30, 2009 | 2002 Pontiac Firebird
Starter problems-starter works fine sometimes
I would try replacing the starter relay
Apr 03, 2009 | 2000 Dodge Caravan
Abs light turns on and off
I had this problem with my 99 Ford, I found that one of the front wheel sensor wires was lying too close to the exhaust manifold it was slightly burned and it shorted out every now and then, I moved it and taped it and it works fine
Mar 23, 2009 | 2000 GMC Sierra
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
Sony FD Trinitron WEGA KV-27FV17 27" TV Logo
12 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
