Question about Lionel The Polar Express Train Set
Smoke unit not working
The unit is on. train runs but there is no smoke
Unit will not smoke, this is the second time I ran train.
have you added the correct amount of smoke oil to engine ?
part number 6-37841 lionel
Dec 29, 2015 | Lionel 31960 The Polar Express O Gauge...
The smoke unit stopped working. been run only 5 minutes
??? not sure why a evolution would have a smoke unit in it , but anyways its possible that trains were shipped with only a small amount of smoke fluid in them (makes shipping less messy) a bottle of smoke fluid and a few drops of this wonderful stuff is all you should need to get your engine smoking again
Aug 27, 2015 | Lionel Canadian Pacific Es44ac Evolution...
Smoke unit doesn't smoke
First verify wire connections (use a Volt/Ohm meter if you have one). Second, verify RESISTANCE in the smoke unit coil wire. Chances are it will be "Open" and reading zero (0) resistance. Acquire new wiring through eBay or Amazon ... and re-wrap the wiring as per the number of wraps as per your Lionel Repair Manual.
Apr 06, 2014 | Lionel 8141-50 Smoke Unit
Hello just opened polar express ready to run freight set o gauge Transformer on solid green light lights whistle smoke work All switches to on Train won't budge Any tips Thanks
The instructions are sometimes a bit vague: for example, once switched on the train needs to sit and charge before it runs, but that is not very evident from the instructions and many folks spent some frustrating minutes wondering why the train wouldn't move.
Jan 04, 2014 | Crafts & Hobbies
Www support toys1628 com
Check that you have added the smoke fluid (oil) to the engine and that it has not run dry. The smoke from the engine is generated by a small chamber with a heating element built in. The heating element gets hot as the loco runs and heats the smoke fluid up which in turn creates the steam/smoke. If there is no fluid the heating element can over heat and will smell as you describe. Not sure if your model has a smoke effect on/off switch, if it has switch it off if you do require the smoke effect.
Dec 27, 2013 | Northpole Lionel North Pole Steam Engine...
Smoke will not come out of harry potter O gauge engine after filling the smokestack with smoke oil
I think you hit the nail on the head with your own question. "filling the smoke stack with oil". Turn the unit upside down and drain COMPLETELY all oil in the smokestack. Generally only a couple of drops are needed. Those drops will smoke until they quit. A couple of drop should smoke at least 10 minutes or more.
Dec 13, 2013 | Lionel 8141-50 Smoke Unit
Were to put smoke fluid on a lionel 8141
If you are asking about the 2-4-2 scout type, a few drops down the stack.
If you are asking about the diesel switcher, it has no smoke unit.
Feb 24, 2013 | Lionel 8141-50 Smoke Unit
Locomotive no longer smokes
If the smoke unit was working, and no longer does, it may be burned out. Did you turn the unit off after running it out of fluid? If not, it will need to be replaced. The switch is behind the smokke box door on the front of the boiler. I'm not sure if the smoke unit is a warranty replacement part, but a check with Bachmann Parts & Services & they will give you an answer.
http://www.bachmanntrains.com/home-usa/prod_serv.php
Your Locomotive is commonly called the Bumble Bee.
Jan 14, 2012 | Bachmann G-gauge Big Hauler - Ebt Boxcar...
Polar Express locomotive will not smoke with smoke fluid in stack and smoke switch on.
You may have to check if there is power to the heating element. You can also check to see if there is too much fluid. You can also put the engine in neutral and tap the chimney hole a few time to kind of "prime" the smoke unit.
Mar 16, 2011 | Lionel Polar Express Train Set
Lionel The Polar Express Train Set Logo
111 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
