Question about Dell Inspiron 1521 Notebook
My inspiron1521 ac adapter is not recognize
When i plug in my computer to the ac a message pops up telling me that the ac is not correct and it doesnt have the 65 watts that it needs
    Problem Solver:
  • 13 Answers
You probably need a new AC adapter. The best option is to find someone else with the same laptop adapter and try theirs. If it works then you know you need a new adapter. You can try and go to a store and purchase a generic one for you laptop if you do not have someone to swap with and take it back if it does not work. If it is still under warranty then Dell will send you a new one.
Posted on Jun 14, 2009
My computer says it dosent recognize my ac adapter
well introduce them(just kidding)
check that the plug is seated on the adapter going into the laptop
otherwise, there may be an issue with plug, adaptor or the place it inserts
might need a new adapter not that expensive really
May 23, 2012 | Dell Inspiron 1318 Laptop Computer PC...
My PRS-300 is not holding a charge nor syncing to my computer. Help please!
To charge a PRS-300, you need an AC-Adapter (wall plug) from a PSP console.
As for the syncing problem, you may need a new USB cord.
Feb 09, 2012 | Sony Reader Pocket PRS-300
I have an Engage wireless mouse that has worked fine for about 6 months and now when I plug the adapter into my laptop (Windows 7), a message shows up USB Device not recognized. I have search for driver...
Does that message pop up when you plug it into every available USB port? Are your batteries charged? Is the mouse recognized on another computer?
This could mean that your USB port is dead or dying (unlikely) or that your mouse adapter is fried.
Try it on another computer, if you get the same message, it's off to the store for you!
May 19, 2011 | Dell Computers & Internet
My latitude D530 laptop doesnt recognize the ac adapter anymore a screen tells me to reset the adapter, how do you do that. I been using this adapter and battery for awhile now it doesnt recognize it
The AC adapter has a small wire in the center of the connector to the system. This sensing wire, if bent or broken will cause the error you mention.
If it's still under warranty contact Dell Support. If not, you'd better buy one replacement.
Try this link: http://www.chargerbuy.com/replacement-dell-latitude-d530-ac-adapter-65watt-19-5v-3-34a.html
Mar 09, 2011 | Dell Latitude D530 Laptop AC Power Adapter...
How do I get my computer to recognized my new ac power adapter?
The computer doesn't need any drivers to recognize an AC Adapter. If you have purchased the correct AC Adapter for your laptop then it should just work when you plug it in. If it does not then my guess is either you have received a faulty AC Adapter or the DC Jack which you plug into in the back of the laptop is bad.
I am assuming your battery is dead and when you plug it in and turn it on nothing happens?
You can also try taking the battery out and try to power it on with the AC Adapter plugged in.
The Dell Latitude D610 takes a PA-10 or PA12 AC Adapter. It's 65W or 90W
For 90 watt Adapter the output voltage on your AC Adapter label should read 19.5V and 4.62A
At least that's what the Dell brand reads so it should be close to that.
Jan 20, 2011 | Dell Latitude D610 Notebook
My dell inspirion ac charger will keep computer running but will not charge my battery. A pop up will inform me that the system doesnt recognize the charger.
it could be a couple things: Are you using the standard 90 Watt ac adapter, or the Travel auto/Air adapter. The travel adapter is only 65 watts can will charge the battery
If using the standard ac adapter, see if you can try another Dell D series adapter and see if you get the same error.
If same with another adapter, the issue is the charging circuit. If another adapter works, then replace the adapter.
If the charging circuit is bad, it will be the chargerboard or if intergrated, the motherboard
Sep 25, 2010 | Dell Inspiron 1545 Notebook
Charger isnt recognized
Dell portables use a sensing wire in the barrel of the adapter plug to determine the wattage of the ac adapter. If that fine wire in the center of the plug is bent or broken, the system cannot ID the adapter and the battery charger is disabled.
SO, first try a known good AC adapter for a D-Series Dell (You might be able to check with Geek Squad at a local Best Buy if you don'e have access to another ac adapter) If a known good ac adapter works, then replace the ac adapter.
If a known good AC adapter does the same thing then the fault is in the charging circuit of the motherboard and the motherboard will need to be replaced.
Oct 03, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 1545 AC Adapter error message
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit support.dell.com
NOTE:other computers may have different BIOS, if it is not the same you may have to consult manufacturer
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Sep 29, 2009 | Dell Inspiron 1545 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 AC Adapter error message
The Dell 1501 ac adapter (possibly other Dell’s as well) has been known to be problematic because of its lack of a plug to jack secure fit. You will notice that the plug can all too easily be pulled from the jack, as opposed to other systems where the plug fits more securely onto the jack. The plug and jack combination is poorly designed so that over time, the plug will come unseated depending on how much movement the machine is subjected to. This will result in power error messages or outright power-up failure. So before assuming you have a faulty adapter, make sure that it is not just a loose plug that is causing the problem. If you look inside the jack, you will notice that there is a 3mm region of non-conductive material nearest the surface of the jack. Use a strip of standard electrical tape 3mm wide and long enough and wrap it around the base of the plug (you may need more than one layer of tape to get a good fit). I have used this method to secure my plug and it has served me well. If the tape comes undone over time, just simply replace it. A more “elegant” method would be to use an “O” ring of the appropriate size (about 6mm) around the base of the plug in lieu of the tape.
Jul 26, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1521 Notebook Logo
57 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
