Question about SWANN Pro-642 Indoor/Outdoor Security Camera
Swan camera showes green image at night
I have one camera on the system that during night time there is horizontal lines in the image, and the other camera shows a green image one instance then back to balck and white
My Z1275 has developed intermittent horizontal lines on the view screen when the camera is moved, and on images some times. Get good images if I use tripod and shutter delay. Looks like loose connecti
When having bright lights on a dark background, you can have horizontal lines. That is supposed to be normal. but the camera should give good pictures in bright light. Try setting the camera in automatic. most of the time it is the green camera loge on the mail dial.
Jul 21, 2014 | Kodak EasyShare Cameras
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture...
The shutter flex cable inside the lens is broken. Happens to all cameras from Canon A4xx series. At day the images will be overexposed with horizontal lines on it, but it could look better at dark / night. The FLEX has to be replaced. Canon doesn't supply new flex cables for these, but there are some cheap copies on ebay. But as these brake very often, I wouldn't suggest you investing money in this camera, because it will brake again sooner or later.
Jan 26, 2011 | Canon PowerShot A470 Digital Camera
My Canon Camera Powershot A470 has been registering the shot images, showing them with horizontal lines across the image. The lines look like the ones on the start-up "Canon" image when you open the...
there is a recall on the Powershot family lens.
check this Fixya's tip:
http://www.fixya.com/support/t114938-canon_digital_camera_recall_defective
Oct 18, 2010 | Canon Cameras
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
Hi, i am Lata and the problem i face is the screen appears dark with circular dots resembling stars in the sky on a dark night. Images cannot be viewed and when i click there appear some horizontal lines....
hi, i am del and the problem i face is the screen appears dark with circular dots resembling stars in the sky on a dark night. images cannot be viewed and when i click there appear some horizontal lines. what could be the problem? Can you help please? Rgds del
Apr 21, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Re: Blurred Image, horizontal lines, photo taken during the day
my friend ur CCD is getting weak this is the first sign of the problem when u get lines hor and vertcal and sun light pics are blurred and over exposed after that this problem extends to the indoor shots as well pls confirm it thru service centre for 100% ,
pls do rate me i know it is a difficult moment but i helped u in diagnosing ur problem without wasting time
Mar 03, 2009 | Sony DSC-T70 Digital Camera
Camera malfunction on Picture and Video
take the phone and have the camera replaced on the phone.
srnvs - the firmware needs to be reflash on your phone to correc this issue....take the phone to a mobile service center to have this done or try online at topsony.com.
May 17, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Flashing horizontal stripes on screen while shooting
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 18, 2007 | Canon PowerShot A70 Digital Camera
Blurry white image when pics are taken during broad daylight
Try first to reset your camera. Press the menu button, go over to setup, go down to reset, press the right arrow, highlight reset and press set. Don't worry it won't erase any of the pictures on your memory card. If that doesn't work you can try and manually set the white balance on your camera and I would recommend sending it into repairs if that doesn't work since it's taking nighttime pictures fine. :)
Dec 07, 2007 | Casio Exilim EX-Z55 Digital Camera
SWANN Pro-642 Indoor/Outdoor Security Camera Logo
53 people viewed this question
Top SWANN Home Security Experts
gaucherre
Neil Frazier
Neil Frazier
Level 1 Expert
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
