Question about Dell V525w Wireless All In One Inkjet Printer
Usb composite device is an older usb device and might not work with usb 3.0
Cannot print, printer spitting out pages of odd symbols
4 Suggested Answers
dan231
  • 236 Answers
SOURCE: I will print a fax
I agree with Democritus, it sounds like a driver issue. Check for a new driver for your printer.
Posted on Dec 05, 2008
cq92
  • 184 Answers
SOURCE: Prints a single line of gibberish on 1 page
A line of gibberish either indicates a the correct printer is not selected as default if more than one printer is installed or the printer driver is incorrect or has become corrupt. To fix incorrect printer, right click the printer and select - "set as default" - you may also have to tell the program you are using which printer to use - when a print is done be sure the correct printer shows in the drop box at the top.
If the driver is incorrect or corrupt - uninstall the driver and printer and completely re-install printer and driver. Using vista - be aware that there are usually two different driver types - a 32 bit version and a 64 bit version - use the correct driver for your version of Vista. Usually the driver file will be marked in the file name either 32 or 64 - either will install, but usually only one will work properly. If you are using the driver from the printer disc - it may be the wrong version and you may have to go online to get an updated driver.
Posted on Nov 04, 2009
techabhishek
  • 66 Answers
SOURCE: Dell 924 printer. Stopped working - when try to
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Posted on Mar 26, 2010
Can't print because of Error-offline status.
I found out that the IP address on the printer was different from the IP address that was available when the printer was first installed. After spending days trying to fix this, it was resolved in less than two minutes.
Go to the Printer Folder in the control panal and choose to Add a Printer. You will see the option to add the new printer ( wireless). Chose to install, and it will install the printer under the new IP address. It worked instantaneoulsy.
You also need to make sure the IP address is inputted into the printer ( check your guide for how to input the IP address)
What I dont know how to do is to keep the IP address static. Afger, it is not practical to do this each time it changes. If only the last digit changes, it may be as easy as switching to the printer available under the current IP address.
Cheers,
DeniseA
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Printer stopped printing and says its off line!
HI,
Im Rizwan from India, i would to tell u to check few things that will resolve this problem
SOLUTION:
NO 1: Check the Connection and power
1.Check the USB cable and the power line to the printer.
2.unplug and replug the cables at the PC an printer end.
NO 2:Check the printer status in control panel.
1.Click start - >Run.
2.In the run window type "control" (without quotes).control panel will open.
3.In the control panel, look for printers and fax and check the printer icon.
4.If printer icon says Offline, Right click on printer icon and select "use printer online"
5.Try printing, if it didnt print follow step NO 3.
NO 3:Restart the USB Composite Device.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET 720C
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Try printing Now, if it didnt work please response.
Thank you
Rizwan
rizwan84tx@gmail.com
Dec 06, 2008 | HP DeskJet 722c InkJet Printer
Printer won't print.
If the cable you are using is USB.
Try these steps.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : HP Office jet 7400)
6.Connect the USB after reboot, you will get pop up "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Mar 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printer (nothing but trouble)
The Cause of this problem is when the printer ran out of paper, few jobs got queued in the print spool memory.just follow my solution.I guarantee the issue resolution.
[Note:if you want me to fix the problem, u can contact me on my yahoo(jack_36623@yahoo.com), i can also take remote access on your PC and i can work on your PC to fix the problem.]
Solution #1:
1.Click start - >Control panel - >Printer and faxes.
2.Right click on the Hp Deskjet F300 printer ICon and select "cancel all document"
3.
Disconnect the USB cable and Restart the PC.
(if it doesnt works go to Solution #2)
Solution#2:
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : HO DESK JET F300)
Cheers
Happy Printing
Regards
Riztech
Mar 14, 2008 | HP DeskJet F380 All-In-One Printer
Cannot print
Try uninstalling and Reinstalling the Printer USB Driver.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : HP Deskjet F300 )
Thank You
Riz
Mar 13, 2008 | HP DeskJet F380 All-In-One Printer
HP All-In-One Printer
I think that the Drivers have failed to communicate.Just try the steps below.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP Photosmart c4100)
Mar 12, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP Printer photosmart C4180
Hi.
Thanks
Riz
Mar 10, 2008 | HP Photosmart C4180 All-In-One InkJet...
Won't print.
It must be the USB drivers problem in communicating to your PC.Thats the reason it says offline.Try the below steps and PLEASE let me know what happened!!!!
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : Compaq LJ1200 )
Thank You
Riz
Feb 15, 2008 | Compaq Inkjet Ij1200 Printer
Datamax M-4208 shows ready but does not print
I belive that, PC can detect the Printer and the only problem, the drivers are unabled to route the print queue and that creates a problem.
If your OS is XP/Vista/2000, try the below steps.
4.Check for the "USB Composite Device" and right click on it, click Uninstall. ((IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : Datamax M 4200)).
Feb 09, 2008 | Datamax M-4208 Thermal Label Printer
Dell V525w Wireless All In One Inkjet Printer Logo
77 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
