Question about Protron PD-800 DVD Player
Menu navigation without a remote control
I do NOT have a remote and would like to know how to navigate the menus on dvds
Tuning goodmans ld2667d tv without remote
Without a remote control; you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes.There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices.After confirming this, check the sites linked here.Both the sites have set-up code list and set-up procedure to many popular brand remote controls.Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability?Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brandyou have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack.Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/Check this site too.http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Sep 21, 2014 | Televison & Video
Tip
HOW TO ENTER SERVICE MODE MENU TO PANASONIC TVs
This is the way to enter service mode menu to most of the Pansonic TVs.
1. Press and Hold Down the [Vol-ve] key, on the front panel of the TV set.
2. Press "Recall" button on the remote control three times.
The service menu window will appear.
3. Use digits [1] & [2] keys on the remote control to navigate Main Menu items.
4. Use digits [2] & 4] keys on the remote control to navigate sub Menus.
5. Press [Vol+ or Vol-ve] keys on the remote control to change the data value to selected item.
6. Power OFF the TV, by its main Power ON/OFF switch to save the adjusted value into memory and to exit from service menu. When you switch ON the set for the next time, it will come alive with adjusted parameters.
on May 20, 2012 | Panasonic Televison & Video
How to change ip address on hp 5500ps
There are three ways of configuring IP address on any HP Printer:
A.- Using the control panel
B.- Using the web server
C.- Using the Jet Admin Utility
We'll deal with the contro panel setup.
To access the contro panel menus
1. Press OK (Check Mark) button once to access MENUS.
2. Press Up Arrow or Down Arrow buttons to navigate the listings.
3. Press OK (Check Mark) button to select the appropriate option.
4. Press Return to return to the previous level.
5. Press OK (Check Mark) button to exit the menus
So to configure IP address:
Press Check Mark
Navigate to the CONFIGURE DEVICE Menu using Down Arrow (the menu scrolls, so you may use any combination of Up/Down arrows)
Navigate to the I/O Menu
Navigate to the EIO 1 menu
Navigate to TCP/IP
Navigate to BootP entry
Press Check to disable it (Off)
Press return
Navigate to IP Address, press Check
Use Up/Down buttons to change the address, check to move between octets.
When finished, press Return
In the same way, enter Mask and Default Gateway
Press Return until you are out of the Menus.
Done
Jul 30, 2014 | HP DesignJet Office Equipment & Supplies
How to get Menu service
1 Press Home to access the Home menu.
2 Press the Navigation buttons to select the SETUP menu and press ENTER.
3 Press the Navigation buttons to scroll to one of the following menus and press ENTER.
4 Press the Navigation buttons to scroll to the setting or option you want and press ENTER.
5 When you are finished, press EXIT
hope it helps. :)
May 08, 2014 | LG 42LD550 42-Inch 1080p 120 Hz LCD Hdtv...
Navigate DVD menu without remote
You can't navigate the DVD menu, without a remote control.
Apr 23, 2013 | Sylvania NB111 Remote Control NB111UD
My tv is stuck in retail mode, how do i reset that?
Enter the OSD menu by pressing Menu on the remote or the TV. Press the down arrow to reach Installation (bottom of the list) and then press the right arrow to to enter this menu. Then navigate to Preferences (third in the list) and press the right arrow. Then navigate to Location and again use the right arrow to enter this item. Set the unit to Home instead of Shop. Press OK on the remote to save the setting. Then press Menu to exit the OSD.
If you are using the controls on the TV, use the Volume +/- buttons to navigate left or right in the menus. The Channel Up/Down buttons will let you navigate the vertical menus.
Once in the Home Location, you can adjust the color or brightness. From the Menu, choose TV settings and then Picture.
I hope this helps.
Dec 07, 2010 | Philips 50PFP5332D 50 in. Plasma...
How to print a usage page for HP color laserjet CP2025n
You can print usage page as follows via front control panel on the printer itself.
  1. Control-panel display: The display provides information about the product. Use the menus on the display to establish product settings.
  2. Back arrow ( ) button: Use this button for the following actions:
    • Exit the control-panel menus.
    • Scroll back to a previous menu in a submenu list.
    • Scroll back to a previous menu item in a submenu list (without saving changes to the menu item).
  3. Left arrow ( ) button: Use this button to navigate through the menus or to decrease a value that appears on the display.
  4. OK button: Press the OK button for the following actions:
    • Open the control-panel menus.
    • Open a submenu displayed on the control-panel display.
    • Select a menu item.
    • Clear some errors.
    • Begin a print job in response to a control-panel prompt (for example, when the message [OK] to print appears on the control-panel display).
  5. Right arrow ( ) button: Use this button to navigate through the menus or to increase a value that appears on the display.
  6. Cancel Job (X) button: Press this button to cancel a print job whenever the attention light is blinking or to exit the controlpanel
    menus.
Now follow these points to print th required page:
  1. Press OK to open the menus.
  2. Press the Left arrow ( ) or Right arrow ( ) button to navigate to Reports, and then press OK.
  3. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the reports, and then press
  4. OK to print a report.
  5. Press X to exit the menus.
The following information pages are available:
  • Demo page
  • Menu structure
  • Configuration page
  • Supplies status page
  • Network configuration page
  • Usage report
  • PCL font list
  • PS font list
  • PCL6 font list
  • Color usage report
  • Service report
  • Diagnostics report
SOURCE
Oct 25, 2010 | Computers & Internet
Ive lost my remote for DGM LTV 3204H how do i install without one
use buttons on the tv there should be a menu and vol up/down and chanel up/down use these to navigate throw the menus
the fitst one press menu
Nov 08, 2009 | Televison & Video
Close captioning
Hi ckay31,
If your remote is not allowing you to navigate through the menus, you may need to replace the batteries.
If this does not work, in the meantime you should be able to navigate the menus using the menu button on the TV. The Closed Captioning option should display under Channel Settings.
If you are still unable to get your remote to function properly, I recommend you contact Westinghouse Customer Service at (866) 287-5555. You may also view your product's manual at http://www.westinghousedigital.com/pdf/15_User_Manual.pdf
Thank you,
Jason,
Go Ahead. Use Us.
Jun 16, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Protron PD-800 DVD Player Logo
35 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
