Question about Icom CS-A110 Cloning Software for the IC-A110 Radio
Selecting a frequency
How do you select a frequency?
    Sergeant:
  • 435 Answers
Do you have a license
Posted on Feb 11, 2015
How to install prophet bushiri channel on dstv
PROPHETIC CHANNEL SETTINGS on Your DECODER(DSTV)
Step: 1 Press menu Select "Advanced Options" Select "Dish Installation" Enter the pin "9949"
Select "Network Configuration" Select "Network 2 Setup" NB: Leave "Network 1 Setup (Home)" unchanged!! Set Signal Setup to "Enabled" by selecting it, and moving left or right Set Frequency to "11170" Set Symbol Rate to "26652 Set Polarization to "Vertical" Set FEC to "3/4? Select "Accept these settings"
Step: 2 Select "Network 2 Setup" Set Signal Setup to "Enabled" Set Frequency to "12682" Set Symbol Rate to "26657 Set Polarization to "Horizontal" Set FEC to "1/2? Select "Accept these settings"
Step: 3 Select "Network 3 Setup" Set Signal Setup to "Enabled" Set Frequency to "12722" Set Symbol Rate to "26657 Set Polarization to "Vertical" Set FEC to "1/2? Select "Accept these settings"
Step: 4 "Accept these settings" to go back to the "Dish Installation" menu then Select "Scan All Networks" Your decoder will go into scanning mode and might take a while to scan all networks. Do not interrupt the process even if it seams to take longer than you expected! Once completed, your picture will return as normal.
ENJOY WATCHING PROPHETIC CHANNEL.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Nov 19, 2016 | Televison & Video
How do I access the settings to change the area for local fm frequencies?
Which radio do you own, first of all? Also you MUST unplug any cables from the audio connector - THEN - you can go to "MENU" and select your frequency. If you have an audio cable inserted, nearly every unit will NOT let you select the FM frequency. Okay? Thanks.
Apr 04, 2015 | Audio Players & Recorders
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Custom programing the radio
To set Radio options, press submenu in Radio
mode.
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
Jun 28, 2010 | SanDisk Sansa e250 MP3 Player
Keeps on locking out channels how do you un lock
Here it is, straight from the manual:
clearing a locked-out frequency
To clear a locked-out frequency, select that frequency (see
“Reviewing Locked-Out Frequencies”), then press CL.
If all locked-out frequencies are cleared within a bank, No
Lockout appears.
clearing all locked-out frequencies in a search bank
1. Press SRCH.
2. Select the search bank in which you want to clear all
locked-out frequencies.
3. Press FUNC then press L/OUT. Lockout list appears.
4. Press FUNC then 6. Clear entire list ? Press 1 to clear all, any
other key aborts appears. Press 1 to clear all locked-out
frequencies. List cleared. appears for about 2 seconds.
Press any key other than 1 to cancel clear.
I hope this helps. If it does, please take a moment to give me a rating. A rating of "very helpful" would be greatly appreciated.
Nov 23, 2009 | Radio Shack Pro-97 Handheld Scanner
After change from 14 to 15 inch LG monitor ,got the frequency problem
Hi You can change the refresh settings by right clicking on desktop, then select properties-->settings-->advanced-->monitor then select the appropriate refresh frequency
Nov 05, 2009 | Computers & Internet
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jul 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
How do i change the channel?
Selected Channel:
frequencies. Figure 16.
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
UNIDEN BEARCAT BCT 15
Editing a Frequency:
[MENU] �� Program System �� F
�� Select a conventional system �� F
�� Edit Group �� F
�� Select a channel group �� F
�� Edit Channel �� F
�� Select the channel �� F
�� Edit Frequency �� F
Use the [0] to [9] and [.No] keys to enter or modify a frequency. When you press
the first place key, the cursor automatically moves one character to the right. You
can also ��, clockwise or counter-clockwise to highlight any digit.
If this does not help, and you need the owners manual, here is a link to the pdf format manual on Uniden:
http://www.uniden.com/index/manuals_results.cfm?cat=3
Jan 09, 2008 | Uniden TRUNKTRACKER III
Utilizing two microphones
No, when you buy multiple wireless mics you have to select different channels per unit if you want to use them on the same stage.
hope this helps
thanks for your rating
Jan 09, 2008 | AKG (WMS40DIV444US54) Microphone
Icom CS-A110 Cloning Software for the IC-A110 Radio Logo
66 people viewed this question
Top Icom Radio Communications Experts
peter0911
spencer hughey
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
