Question about Oxo Good Grips Stainless Oil Stopper/Pourer
Oil stopper does not seal
Can not fine a bottle that the stopper will seal
Water is draining from hot tub after its filled & dont know why
Hi Mary,sounds like your drain stopper may not be closing tight.Try removing the stopper by turning it counter clockwise,then jam a small rag in the drain as tight as you can to stop the water and fill the tub.If it still leaks then the drain plug where the stopper goes may have to be re-sealed or one of the jets may have a leak.If the tub is over a ceiling do not keep re-filling the tub you will cause major water damage to the rooms below.
Jan 05, 2014 | Leisure Time Filter Clean 1 Quart - 12...
My 91 honda civic has alot of white smoke coming out of the exhaust, and have oil on the spark plug in the #3 cylinder not sure what the problem is (bad vaulve/seal)??? one month prior to problem blew...
I'll tell you what few might be problems
Oil on spark plug could be:
1. bad cylinder rings 2. value seals
For Value Seals you will take off head again and then take off value over. Take all (Lifters or Cam) and springs off and you will see seal rings in each of values.
For cylinder rings, you will maybe need to take motor out and take head off, oil pan and rod bearing unbolts to get cylinder out to replace new rings. Or you can try do that without motor out. just take oil pan off under the car.
Try change oil with 1 qt of Lucas Oil and 4 or 5 normal oil. Best oil is Castol High Mileage
Lucas Oil should help stop leaking oil inside the cylinder. Or another kind bottle called (Stop Smoke) at auto store.
Feb 13, 2011 | 1991 Honda Civic
Hi what can cause the engine oil to push out from the dipstick plaese assist thanks John
Hello John. It might seem like your stick's ring (that rubber stopper that acts as a seal) has worn out. You need to replace the rubber seal or ring. If that cant be done, then perhaps getting another deep stick will help you solve it.
Dec 03, 2010 | 2002 Land Rover Freelander
How long can I keep my perfume before it “turns”?
Some industry experts say that perfume should be replaced every year, but properly stored, perfumes should last much longer. Most perfumes will keep several years, some will keep many more years than that.
To store perfume properly, keep it away from heat and light. A dark closet or a covered box is best. Also avoid direct exposure to air. Splash bottles, which expose the fragrance to air every time they are opened, are problematic. Consider decanting into a smaller atomizer for regular use. If you apply perfume directly from a bottle stopper, wipe the stopper with a clean, lint free cloth before replacing it in the bottle.
Nov 23, 2010 | Health & Beauty
I have akohler bath drain that seals/drains simply by pushing down on the gasketed spring-loaded chrome stopper. The drain is clogged with hair but I can not figure out how to remove it and snake the...
Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
May 21, 2010 | Plumbing
Noticed what looks like lithium grease inside the oil fill cap while i was changing the oil..what is it????
this means that you have a headgasket leak flush the system take out the antifreeze fill with just water put in a bottle of block seal / headgasket sealer run the engine for about 3 to 4 hrs then flush out the system again and fill with antifreeze (remember that block seal will clog your system (if) you don't get all the antifreeze out ( read the label on the bottle (autozone carries block seal) about 25;00 bucks
Mar 08, 2010 | 2004 Ford F150
Fzr1000 fork oil
hello m8,,i had one of these babys,,grab your self a medium grade oil,, if u have a litre bottle u need to put just over a quarter of that bottle in each fork,, or if u have a 500ml bottle pour half a bottle in each fork,, cheers
Mar 24, 2009 | 1989 Yamaha FZR 1000
4.3 oil filter blowing seals
before you put the filter on pour oil into bottle lid and pour on the rubber seal and use your finger to rub oil on seal. it should work
Feb 03, 2009 | 2000 Chevrolet Astro
Smoke from the exhaust when starting
I would think this is valve stem seals that are letting a little bit of oil down on top of the piston and when you go to start the car you get a bit of oil smoke when you start the car
Nov 30, 2008 | 1995 Jaguar XJ6
Oxo Good Grips Stainless Oil Stopper/Pourer Logo
Top Oxo Tools & Hardware - Others Experts
Are you an Oxo Tool and Hardware - Other Expert? Answer questions, earn points and help others
