Question about LG LWD3081ST Electric Double Oven
Lg profile electric double oven clock won't reset
I can change clock time, but it won't work
Pleb30t8ccb
Good Afternoon Friend,
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    How do you get the ge profile oven time set to not on military time. we push clock time and the time, and it defaults to military time.
    I don't know this particular model but on a lot of different brand stoves/ovens the clocks only work on military time. I have encountered many of these and they are manufactured to work on this time only. Unfortunately I have one sitting in my kitchen!
    Mar 13, 2011 | GE Profile JTP56 Electric Double Oven
    Tecnick tck 8522/2 oven
    power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
    Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
    Clock on cooker flashing
    Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
    Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
    Ge profile double wall convection oven
    My solution for the F7 problem may work for you. It won't cost you anything to try it. It is simple and free. You can find it at the following link:
    http://www.fixya.com/howto/h155060-dreaded_f7_error
    Please let me know if this works for you. You can email me at:
    hutchipop@yahoo.com
    Good Luck,
    Powerman
    Feb 03, 2008 | GE Profile JTP18 Electric Single Oven
    Ge Electric Double oVen
    This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
    Aug 09, 2007 | GE JKP45 Electric Double Oven
    LG LWD3081ST Electric Double Oven Logo
    14 people viewed this question
    Top LG Ovens Experts
    Coss
    Mike Carew
    Are you a LG Oven Expert? Answer questions, earn points and help others
