Question about Myphone System Security Wizard
Volume up - Myphone System Security Wizard
How do i increase the volume
Download vs volume and try that
Feb 19, 2015 | Motorola Mobility RAZR V3
MY POWER MAX 5.8 SAYS THAT MY VOLUME IS OFF ON ONE HAND SET--HOW DO I TURN IT ON? THANKS EILEEN CARTER beileenc@bellsouth.net
There are different ways to adjust the ringer and speaker volume on your handset. Please see your owners manual for model specific instructions.
On most single handset units:
Ringer volume: Press the volume up or down arrow rapidly to change the ringer volume.
Speaker volume: When talking on the handset press the volume up and down arrow to increase or decrease the volume.
On other models:
Ringer volume
In standby mode, press the volume up key or volume
down key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Earpiece and Speaker Volume
You can select from among of six volume levels on the
handset, and ten levels on the base. Pressing the
volume up key or volume down key on the handset or
base during a call will change the earpiece or speaker
volume. This setting will remain in effect after the
telephone call has ended.
If you press the volume up key when the earpiece is at
the maximum volume level, an error tone sounds.
The error tone also sounds if you press the volume down key at the lowest volume.
Sergio
Mar 13, 2008 | Lands Phones
Volume
Right click the volume icon then click open volume mixer then check if anything is muted then unmute it
May 05, 2013 | Fujitsu Computers & Internet
I cannot hear any sound out of my Polaroid TDX-01930B television.
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
May 06, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
The speaker volume is too low. I set the bios to 8 and still the volume is very low
Volume for what? New laptops have the mixer effect in the volume pad... one can control video volume, internet broadcast volume, master volume (main volume level), and so on.. check that they all are all the way up (to the max) and controll it with the master volume regulator.
Dec 31, 2009 | ASUS K50IJ-C1 Notebook
NO SOUND WHEN IM ON MAX VOLUME
There are 3 types of volume: master volume, in-call volume, and multi-media volume. To adjust master volume, press and hold the thumb wheel until the volume control comes up and use the wheel to adjust it. When in a call use the thumb wheel to adjust the in-call volume. Finally, use the thumb wheel to adjust the volume of multi-media while it's playing. One thing to keep in mind, the master volume will override the multi-media volume, so if you can't hear the multi-media after turning it all the way up, you might try raising the master volume fist.
May 21, 2008 | Motorola Mobility Moto Q
Volume&thinkpad button
Most IBM / Lenovo Thinkpads have hardware volume control with apropriate buttons above the keyboard (volume up, down and mute). Gnome in Ubuntu is configured in such a way, that the keypresses are trapped (this is correct), apropriate volume window is displayed (correct) and Gnome volume control is modified. Last step is actually wrong - the keys in Thinkpads control the volume hardware directly, so every keypress turns the volume up/down regardless of sound card settings (in Ubuntu case - this would be Alsa mixer). Current behaviour results in volume being changed twice - for example if I press the volume up button, I get volume reduction via Gnome sound mixer plus volume reduction via hardware control. Effectively this creates an exponential (and not linear as it should be) volume change. In short - it is very difficult to control volume, especially relatively quiet sounds, with volume keys only.
The "patch" solution is to decouple Gnome mixer from hardware buttons. Of course it could be done manually, by deleting apropriate key actions in System->Preferences->Keyboard shortcuts, but this also disables windows showing volume. A better thing (but more complex) would involve reading /proc/acpi/ibm/volume and displaying the volume window according to this value at each volume button keypress.
I tested this on T21, T42 and Thinkpad 600. I guess only some R series notebooks (R31 etc.) would not be affected, as these do not have hardware mixer.
Steps to reproduce:
1. Press hardware volume key (eg. volume up) on a Thinkpad
2. Observe the volume change - it is changed in hardware mixer (correct) and in Gnome volume control (incorrect)
I hope this helps...
Apr 18, 2008 | IBM ThinkPad R31 2656 Notebook
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
Mar 15, 2008 | Polaroid FLM-2632 Television
Computers & Internet Logo
22 people viewed this question
Top Myphone Computers & Internet Experts
David Payne
David Payne
Are you a Myphone Computer and Internet Expert? Answer questions, earn points and help others
