Question about Amana ARS9265B Side by Side Refrigerator
AMANA refrigerator Model Number ARS9167AW - How to reset change water filter light
catriver
  • 878 Answers
SOURCE: No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Posted on Nov 12, 2006
catriver
  • 878 Answers
SOURCE: Amana ACD2234HRS replacement water filter
Don, I have a manufacturers part number of 67003591, you might be able to cross reference that. Straight from the manual..Catriver.
Posted on Jun 21, 2007
SOURCE: Water filter light on refrigerator
Found this site and the fix worked for mine. You need to press a combination of buttons and this tells you which ones
http://www.partselect.com/water-filter+reset-change-filter-light+repair.htm
Posted on Aug 08, 2008
22yooper
  • 828 Answers
SOURCE: Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Posted on Dec 02, 2008
SOURCE: Can't reset indicator lights when water filter is changed
My manual says to "Press and hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 seconds). The control is now reset for 12 months or another 416 gallons.
Posted on Aug 12, 2009
Amana AR2664bw dispenser lights
Are you talking about the inside lights are the dispenser lights?
Nov 01, 2008 | Amana Refrigerators
New filter installed. how to turn off "change filter" light
There is usually a reset button near the change filter light. Without the model number I cant tell you exactly where.Please comment me back so I can further assist.
Jul 30, 2011 | Refrigerators
Where is the water filter on the amana #scd25tw
The Amana with model number SCD25TW does not have a water filter. You would have to install an in-line filter on the water supply line if you want to filter the water. If your talking about the model number ARS266ZBS, then open the refrigerator door and look at the top right hand side. You should see a filter housing with a tab to release. Once released you have to remove the filter from the housing to replace it. When finished be sure to run about a gallon through the dispenser, to flush any air out of the system.
Mar 23, 2011 | Amana ARS266ZBS Side by Side Refrigerator
How do I reset the water filter change light after changing the water filter?
press and hold the water filter button for 10 seconds. and it should reset
Mar 03, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Changed water filter red light stays on
you will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
May 27, 2009 | Amana ARS2464B Side by Side Refrigerator
The warning light to reset filter came on. I've
Resetting your Refrigerator filter indicator light after changing your water filter Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Once these two steps are completed, you are all set to enjoy great tasting ice and water through your refrigerator. If you don't see your manufacturer listed or the insructions don't work for your model please post a comment with your make and model number so that we can provide exact instructions for your model.
May 06, 2009 | GE PDS22LBN Bottom Freezer French Door...
Where is the water filter in the bottom freezer amana energy saver model refrigerator; and how do you change it?
according to the model number that you gave this particular unit does not have a filter built into it. most amana bottom freezers ahve the filter located in the refrig section on the ceiling. there is a thumb latch you push in and a cover lets down to expose the filter. then turn 1/4 turn counterlokwise to remove. if this doesnt sound right post back wiht a complete model number from the refrig and I will take another look for you. thanks for using FixYa peyton
Feb 17, 2009 | Amana ABB1927DE Bottom Freezer...
Filter change
didnt post the model number, but a general rule of thumb is the filter is in top right section of refrig compartment, a counter-clockwise turn will unscrew and rescrew the new one in
Nov 10, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Nov 12, 2006 | Amana ARS9265B Side by Side Refrigerator
Amana ARS9265B Side by Side Refrigerator Logo
347 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
