Question about AEG 24 in. Favorit 40630 Free-Standing Dishwasher
Wont heat or dry dishes
My AEG 40630 FAVORIT DISHWASHER IS WORKING BUT WONT HEAT UP SUFFICIENTLY TO DRY DISHES
  • 132 Answers
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
Posted on Jun 14, 2009
Whiy does the rinse led blink
you most likely need to add Rinse Aid to the dishwasher.
Jun 10, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Aeg
Here is a link to the manuals site - I suggest you search by PNC number (you should find it on the label somewhere)
http://www.aeg.co.uk/Support/Manuals/
Apr 09, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Aeg dishwasher will not drain
The washer has a drain motor in line with the outlet pipe. The motor must turn when in outlet mode. This motor has an impeler that turns at high speed to pump out water in the outlet mode. The motor could be faulty or the lelectrical push on connectors to the motor loose. One can remove the motor and coonect it directly to the mains voltage for a few seconds to check if it spins (also make sure that nothing is blocking the impeler from spinning).
Oct 24, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
AEG 40630 -top and middle lghit are flashing
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
Dec 27, 2008 | AEG 24 in. Favorit 40630 Free-Standing...
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Upper basket spray arm
Have you checked that the cover for the water inlet at the top where it connects to the spray arm is attached? It could have worked loose. Just re-attach and your spray arm should "miraculously" start rotating again!!
Aug 21, 2008 | AEG 24 in. Favorit 40630 Free-Standing...
AEG 24 in. Favorit 40630 Free-Standing Dishwasher Logo
1,183 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
