Question about Samsung Galaxy Tab Tablet PC
My galaxy tablet turns on but my screen is dark
I hear sounds
Tablet wont turn on fully it freezes on the opening screen than just freezes there and wont turn on all the way what can i do to reset it
How to Fix a Frozen Samsung Galaxy Tablet [Solved] - Samsung ...
www.tomsguide.com/forum/id.../fix-frozen-samung-galaxy-tablet.html
2 days ago - 30 posts - ‎27 authors
I have a Samsung Galaxy Tablet that is completely frozen. ... If done correctly thescreen will turn black and automatically start the reboot process. ... Sure have, it won't turn off, swiping the front screen doesn't do anything. My Samsung tablet won't turn on! - Samsung - Android ...
Jan 17, 2016
My Samsung tablet will not turn on. - Samsung - Android ...
Dec 30, 2015
My RCA tablet won't turn on. What do I do? - Tablets ...
Dec 28, 2015
Help! My tablet won't turn on! what do I do?! - Asus ...
Apr 1, 2015
More results from www.tomsguide.com
Jan 21, 2016 | Tablets & eReaders
Screen is black but is powered on
try factory RESET but first save you info on memory card.
Jan 12, 2016 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
Turn off data on my tablet
I don't know your tablet, but it's generally an options in settings. The settings icon is a sort of gear shape.
Jan 17, 2015 | Samsung 8GB Galaxy Tab 3 Lite Multi-Touch...
My Samsung Galaxy 3 Tablet wont charge
Have you tried a different charging cable?
Did you allow the battery to run down until it was completely drained?
- If so then try the following;
Watch this video (link below). You should only remove the back cover, disconnect and reconnect battery cable. Disregard the rest of the video as I could not find one doing ONLY what you would need to do. Follow the instructions to remove the back of the tablet then disconnect the battery cable(careful not to damage the circuit board), reconnect the battery cable, and replace the back cover. Connect the charger, within a minute the screen on the tablet will pulse/flicker which is good news, allow it to charge a while, turn on the device, turn off the wireless wifi, click the power button to turn the screen dark again, and allow to charge for another 6 hours or till fully charged (when not connected to wifi the background processes will affect the charge time, on a weak charger it may not even charge like from an usb port on a computer).
Again, you should only be concerned with the video up to about the 1 minute and 15 second mark. You only need to disconnect the cable then reattach it. ONLY DO SO if you are comfortable doing so. If you have never worked on electronics before or are uncomfortable find someone to do it for you.
Galaxy Tab 3 Battery Replacement and Screen Repair Disassemble and fix
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My galaxy tablet just went dark. No screen or power. It was more than 50% charged last I looked an hour before. It has been plugged in for 20 minutes now and it won't turn on. What happened??
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
Dec 09, 2011 | Samsung Galaxy Tab Tablet PC
It stopped working, went black and has a sound like a loud fan working. Can't switch it off or do anything with it. Just making this running sound.help please. Fay
HI baring 16 listen You can get do a hard reset on the Samsung tablet. I must warn you that if you do a hard reset on the tablet you will lose all of your data. Next if your hearing a fan sound in the tablet. The tablet it self may be struggling to do simple operations on it. Where did you buy the tablet from. The steps to doing a hard reset on the tablet are as follow. 1 You need to hold both the power button and menu home key buttons at the same time. You will see the reboot screen come up. DO a wipe user information on it. It will begin wiping the tablet. You will have to reset set up the tablet after it is finish.If you still hear the fan sound take it back to the place of purchase for an exchange. Hope this helps
Mar 21, 2011 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy Tab Tablet PC Logo
13 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
