Question about iHome Timex T123L Simple Set Direct Entry Alarm Clock with LED Display, Silver
Set time Can't reset clock
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
Need to reset atomic clock to Virginia time zone; now 4 hours ahead
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
May 31, 2012 | La Crosse Radio Controlled Atomic Clock
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
My SIO/SCAN 31420E did not reset for daylight savings time and I can't find the instructions to reset
how do I change my atomic clock to eastern time zone. Or when I set my time does it automatically set to the correct time zone.
Nov 02, 2009 | SkyScan 86709 Atomic Wall Clock
Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
Feb 08, 2009 | Oregon Scientific Starck Large Music...
Cannot properly reset skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
thanking you.
Nov 19, 2008 | SkyScan 86709 Atomic Wall Clock
Reset cd clock radio? (manual missing)
Make sure the clock is in standby mode, as opposed to playback mode. Press time set button — the clock digits will blink. If they don't, you're in playback mode. Press the hour button to adjust the hour. Press the minute button to adjust the minute. Press time set button to confirm the time.
Sep 30, 2008 | TruTech Clock Radio
Sony dual alarm am/fm alarm clock radio
HOW does one set the time and alarm on a "sony dream machine clock radio"?
Aug 28, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
Soundesign 316G Jukebox Alarm Clock-can't set alarm
Press the alarm reset ( on/off ) for a few seconds.
Same as you do to set the time
Feb 13, 2008 | Novelty Simpson Jukebox Alarm Clock Radio...
Needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Nov 03, 2007 | La Crosse Radio Controlled Atomic Clock
iHome Timex T123L Simple Set Direct Entry Alarm Clock with LED Display, Silver Logo
Top iHome Televison & Video Experts
Electro Med Services...
Are you an iHome Televison and Video Expert? Answer questions, earn points and help others
