Question about Kwikset Locks & Locksmithing
Moisture have a storage shed with a quickset lock. door opens out, no storm door.moisture has been getting in the lock all winter, hard to open, what can i do to remedy this? thanks
    Problem Solver:
  • 15 Answers
A short burst of WD-40 or Triflow into the keyway, then insert and remove your key a few time. After that, insert the key and turn back and forth, it should smooth right out.
Posted on May 20, 2014
2 Suggested Answers
  • 10865 Answers
SOURCE: Get the Lock Off the Door
With the door open you will find a shackle release lever inside of the compartment in the upper right hand corner. To release the shackle push the lever to the right then the shackle will open. Good luck.
Posted on Jan 25, 2009
How to program a garage door remote
Hi, On the rear of the opener you will see a small button! press it and a light will start flashing on the opener (usually green) then press a button on the remote and the door should open.
http://c.shld.net/assets/own/53990e.pdf
Good luck
Sep 03, 2014 | Craftsman 34 Hp Garage Door Opener Chain...
How to reset garage door opener?
Phone number for customer service is usually poste on opener motor housing. Call them they will walk you thru the procedure, simple to do.
Aug 19, 2014 | Craftsman Sears Liftmaster Garage Door...
Moisture has been getting in the lockset, door is on a storeage shed that opens out ,to the weather. how to prevent this?
graphite grease costs about 5 bucks a little tube put on key and insert/turn several times , wipe key off with rag
Mar 22, 2014 | Kwikset Locks & Locksmithing
My passenger rear door on my 2005 nissan altima will not open from inside or outside
It's not the handles I've struggled with these issues on 3 altimas it's the door latch itself it's from moisture it's worse in the winter if I run the car for a couple hours with heat on the door opens also if you repeatedly lock and unlock the door with the power lock it will release eventually. I've been locked in my 04 Altima multiple times and had to lock the door sometimes to get it to hold shut these cars are nutorious for door issues
Dec 23, 2013 | 2005 Nissan Altima
Overhead light will not come on when door is opened
Press and hold the Lock button until the light blinks (about 10 seconds). A single blink indicates that the timer is reset to 1 1/2 minutes. Repeat the procedure and the light will blink twice, resetting the time to 2 1/2 minutes. Repeat again for a 3 1/2 minute interval, etc. up to a maximum of four blinks and 4 1/2 minutes.
Dec 02, 2011 | Craftsman Sears Liftmaster Garage Door...
Steelcraft garage door opener opened but will not close. Motor hums but door does not move.
Ensure proper installation. Ensure gears in main control head box are not worn out, The main drive flat gear is plastic in a lot of these openers. Replace main gear unit are rebuild it.
Apr 24, 2011 | Craftsman 34 Hp Garage Door Opener Chain...
Freezer door "locks" or is hard to open, if opened a few minutes prior?
This is normal. Freezers have a vent port to let high moisture out. When you open the door moisture laden air enters. When the door is closed the hot air from outside expands and leaves through the vent port. This creates a vacuum in the freezer that lasts a few minutes. No problem
Sep 16, 2010 | Sub-Zero Freezers
VW CC 2010 fuel door will not open
If you're experiencing problem under winter cold weather condition, heat the fuel door using an hair dryer blowing air in surface and into the joint.
Once it's warm up tap the fuel door with the palm of your hand during somebody else is operating the trigger. It should work.
Once it's open, apply silicone spray or lub on mecanism and hinges to avoid reoccurence.
Hope it will help
Dan
Dec 19, 2009 | 2009 Volkswagen CC
Problem with Daewoo Nubira doors
try spraying wd40 or similar into the laches, " the ones that lock the door, looks like you ran out of grease and that's why they get stuck, little lubricant " oil " will keep moisture away preventing it from freezing again
Jun 01, 2008 | 2001 Daewoo Nubira
Locks & Locksmithing Logo
43 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
