Question about Balboa Instruments Pool & Spa
Balboa VS500z F4 blows with all motors and heater disconnected
VS500z
4 Suggested Answers
SOURCE: I have been unable to switch operating mode of
I had to wire mine the same - found this on their website - check the bottom left corner - you should be all set. Good luck!
http://service.balboa-instruments.com/appnotes/VS5xx_Config_Guide.pdf
Posted on Apr 19, 2009
SOURCE: What is the difference between
The Balboa VS500Z supports one two speed pump, an ozone, and 12v spa light and an optional circulation pump.
Whereas the VS501Z will support a two speed pump, a single speed pump or blower, an ozone, a 12v spa light and an optional circulation pump.
Basically the two are very similar except that the 501Z will support an additional one speed pump or blower.
The best suggestion if you are doing a replacement is to purchase one of the Value Pack Retrofit Kits available through Balboa. You basically get everything you need for the replacement, including the topside, cables, and overlay.
You can find everything you need to know about making the replacement on the following page:
BALBOA VALUE PACK VS RETROFIT KIT
Hope that helps!
Posted on Sep 09, 2011
  • 111 Answers
SOURCE: I have a Balboa VS500Z . The circuit board burned up where the heater buses are located . I replaced the board and the heater . Know when I start the Spa it primes at low speed for about a minute . Th
DR code - Inadequate water detected in heater.
HL code - Hi Limit, Spa over heat. In your case the Hi Limit is preventing the element from burning out.
This means there is no water or not enough water flowing through the heater.
Common causes:
Hi Limit sensor failure.
Blocked suction, skimmer.
Are the gate valves all the way open/up?
Pump is not functioning correctly, impeller/wet end failure.
These are the most common, but there are also other causes.
I hope that helps
Posted on Feb 27, 2012
Overheat errors
possible temp sensor bad if ok bad control board
Feb 25, 2013 | Balboa Instruments BALBOA VS500Z PUMP ,...
I have a Balboa VS500Z . The circuit board burned up where the heater buses are located . I replaced the board and the heater . Know when I start the Spa it primes at low speed for about a minute . Then...
Common causes:
I hope that helps
Feb 20, 2012 | Garden
What is the difference between a Balboa VS500Z and a VS501Z
Hope that helps!
Jul 12, 2011 | Balboa Instruments Duplex Digital Panel 2...
I have a Balboa Instrument Panel for my Spa. Model # M51500 part #54493-200701300092. My question is the main 50 amp breaker keeps tripping not allowing power to the spa. There is no blown fuses that I...
This is most likely a heater issue. The technician needs todisconnect both heater leads to see if the breaker will hold. This will help you determine where theelectrical problem is occurring and why it is tripping.
You can find answers to common spa orbath problems online at http://www.balboadirect.com/support.aspx Hope that helps!
Jun 01, 2011 | Balboa Instruments Duplex Digital Panel 2...
Hot tub emptied while a way found leak have fixed but heater will not work is this a fuse or what system is a vs500z
The heater works when there is flow through the pump. If the pump is working and the thermal overload switch was reset and still no heater, check all fuses. There may be three or four in the control unit.
Feb 19, 2011 | Heating & Cooling
Pool & Spa Logo
51 people viewed this question
Top Balboa Instruments Pool & Spa Experts
russlakeside
Level 1 Expert
Mike Raino
Level 1 Expert
Are you a Balboa Instruments Pool and Spa Expert? Answer questions, earn points and help others
