Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
Change the password
I want to login to change my password and security setting
Set up wireless
How to Access Netgear Wireless Router Settings
Netgear wireless router settings must be changed using the router's web-based interface. Any computer on the network can be used to access it. From the Settings menu, options such as "Encryption," "Network setup details" and "Passwords" can be customized.
There are a few different variations of login credentials. Though these steps will use the details that work for the most common router models, the alternate login details that other models of Netgear wireless routers use will also be included.
Things You'll Need
Computer connected to the network
1 Open any web browser, such as Internet Explorer or Mozilla Firefox. In the address bar, enter "192.168.0.1" (without the quotes) and press the enter key. This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try "www.routerlogin.net", "192.168.0.5", or "10.1.10.1" until the login window appears.
2 Enter the username "admin" (again, without the quotes), and the password "password" in the appropriate fields, then click OK to login. If that password fails, try "1234," "Password" (with a capital "P"), or "admin" until you are greeted with the settings screen.
3 Make any required changes to the settings. Under security, it is possible to specify a new username and password for added security. Once you are done, close the window, and the system will automatically log you out.
Tips & Warnings
Always secure a wireless network to prevent outsiders from being able to change your network settings.
Jan 09, 2012 | NetGear RangeMax Computers & Internet
Reset password
The default password for the router's Web Configuration Manager is password. NETGEAR recommends that you change this password to a more secure password.
To change the administrator password: 1. On the main menu, under Maintenance, select Set Password to display the Set Password screen. 2. To change the password, first enter the old password, then enter the new password twice. 3. Click Apply.
Best of luck!
Sep 06, 2011 | NetGear WNR2000 Wireless Router
How can i change the password? the problem is i forgot my old pass work.....
Hi
Which password for login password or security key. if you forget the login password then you reset your router and put the password admin, and if you forget security key then lo problem login and open the router go the wireless setting and change WAP or WPA1 what ever you select your pre shared key.
Jun 02, 2011 | D-Link DIR-615 Wireless Router
How do I change my password for a WBR-1310 router?
if you know the current password to the router please login to it by going to
http://192.168.0.1
if you dont the default login/password is admin/admin
once you login go to the tools link
below you can change the password.
if you want to change the wireless network password go to
setup>wireless settings
and change the security password there.
Apr 03, 2011 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
Securing router from outside user.
Set wireless security to one of the options available. Also, set the router system ID, and change router login password, (record it somewhere, like on the actual router) change the wireless channel to 11 to avoid conflict with landline wireless handsets.
There are higher security settings, but wireless access password is pretty effective.
Oct 04, 2010 | NetGear Computers & Internet
Linksys setup
That's because you have to enter the username and password in order to access/change the security features of this router. There are default login/password entries required for security access within the router, even when it's set back to original factory settings.
Check your user manual for the default login information.
Aug 28, 2009 | Linksys Wireless-G WRT54G Router
I need to secure my router. I had payed to have it set up when I was getting my computer fixed only to find out that my son could log on with out a password. How can I fix this.
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
************DETAILS************
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key .
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
Apr 08, 2009 | SMC Barricade 7004VWBR Wireless Router
Cannot access Belkin security settings
avast virus disable it then try it you get the other wise reset the router and re-configure it after reset you get the all configuration in default setting then you easly get it but anti virus disable then work after then you can enable
Feb 26, 2009 | Computers & Internet
Secutiry for BelkinF5D7230-4 router using Vista
Hi, here's a quick guide for you:
1. Connect to the router via Ethernet cable
2. Login to the router via a web browser, by typing 192.168.2.1 in the address bar
3. Click to login, leaving password blank (unless you have set a password)
4. Go to Wireless > Security. Select Security Mode WPA-PSK.
Enter your network key (password) under ‘Pre-shared key’ – make a note of it – click ‘Apply Changes’. That’s it, your wireless is encrypted.
For better security/more details:
1. Pick up a manual from Belkin UK
2. When you’re in your user interface, change the SSID and router password for a better level of security (see this tip for more details).
Hope this helps, but please come back to Fixya if anything doesn't work, or if you need more info. Good luck
Jan 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH Logo
21 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
