Question about Oster Blenders
Signature classic where do I get replacement gaskets for signature classic blender?
I have a B to B 'Smoothie Signature' with a leaking and loose fitting shaft bearing. Can I get it apart and replace or tighten something, or do I need the entire container base?
Here is a link to all of the replacement parts available for a smoothie signature: http://westbend.com/support/replacement-parts/smoothie-makers/sa5red-smoothie-maker-signature.html
I am not sure what you mean by shaft bearing, but if it is not on this list, it is not available.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 18, 2013 | Back to Basics Signature Smoothie Maker
How to replace glass jug
Watch this video. If your jar has a lid that screws in rather than pushes in you unfortunately have to purchase a new lid, blade, gasket and collar.
May 08, 2010 | KitchenAid KSB3 Classic Work Top Blender
Leaking from the bottom of the glass container through the screw
Check the rubber gasket for damage or hardening and also for chipped glass on the sealing surface. Make sure the ring is not cracked causing loss of compression of the seal.
Also check that the leak is NOT at the shaft seal. Replacement parts should be readily available,
Nov 08, 2009 | Oster 4093-8 Osterizer Classic Blender...
The bobby flay blender leaks out the bottom where the blade is screwed in
Take it apart and pit the gasket on the other side of the cutter assembly.
Oct 04, 2009 | KitchenAid KSB3 Classic Work Top Blender
Source for replacement parts?
The lid gasket is not available as a separate piece - an entire lid would have to be purchased. Kitchenaid still has inventory on replacement lids. If you'd like to order, you may call Kitchenaid Customer Service. Their toll-free telephone number is:
1.800.541.6390.
If you would prefer, you may also try MENDINGSHED.COM. They carry a large inventory of Kitchenaid parts, even if the model is out of manufacture.
May 18, 2009 | KitchenAid KSB3 Classic Work Top Blender
Poor function of my Oster classic blender
Yeah, the blades probably need to be replaced. The replacement blade assemblies for most models can be ordered directly from Oster - their phone # is 1-800-334-0759 - you have to go through an elaborate menu tree to get to the right place.
Apr 03, 2009 | Oster 4093-8 Osterizer Classic Blender...
Blenders Logo
41 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
