Question about aFe 2004 BMW 6-Series - 645i, 4.4L V8 - Silver Bullet Throttle Body Spacers
O2 sensors ONLY WHEN COLD START.after 200 yds and i stop at junction, engine goes into limp mode. engine light comes on. I turn off ignition. restart and ok. but if I have to stop again befor engine has warmed up. same thing. but once warm and if I did not have to stop for something I would not know I had a problem
Fuse # 21 blows when igtion turned on.what causes this?
Whatever accessory or system is powered by fuse #21 has a short. It only blows when the ignition is turned on because no power goes to the fuse with the ignition off. If your transmission is in limp in mode, you need to have it checked. You don't mention make, model, or year vehicle, but your car may have a separate transmission control module (TCM); in any case see if you have any codes that indicate if there is a problem with the transmission. The O2 sensors have nothing to do with the transmission being in limp in mode, and I doubt that they are connected directly to the fuse. Most O2 sensors get their power through the PCM.
Oct 25, 2016 | Cars & Trucks
How do I bypass o2 sensor on my 2000 Saturn sl2 3.0 litre
You can't. The computer knows it is there and also knows if you try to wire around it. The electrical output from the O2 sensor is used to control the other engine controls. If you bypass the O2 sensor, the motor turns on the check engine light and goes into limp mode which makes the car run pretty bad
Mar 05, 2015 | Saturn Cars & Trucks
Limp mode on mercedes benz vito 2151cc reg RA51TZP
this is just a list.
crank sensor ( gone will not start engine )
cam sensor (gone will run low revs no timing limp mode)
EGR ( depending on are and ecu settings engine will not run or limp mode activated)
Knock sensor ( engine limited if censored)
MAP/MAF ( Ruff running or will not start/limp mode)
hope this helps this is the out come of the sensors.
Jul 11, 2017 | Brodit GPS
LIMP MODE HOME
The O2 Sensors need to be changed at 100,000 miles,
before they fail & you get a MIL Lamp on your dash
Just the front (2) closest to the engine, at the converter inlet
The ETC Failsafe, is most likely bad COP ignition coils
Have to check for cylinder misfire count with a professional
scan tool in Mode #06,unless you want to spend a few days
walking a new coil from one cyl to the next
Always provide V6 or V8 in your question & lots of detail
Jul 03, 2012 | 2004 Lincoln LS
While driving along my 2005 mercedes e320cdi goes into a limp mode and I don't seem to have a turbo. Once I stop it and turn off the key and let it sit for several minutes it seems to be fine once it is...
Please describe limp mode. wesleygolden@optonline.net Is the transmission effected, or engine performance. how long has the check engine light been on. And do you have starting issues during cold start. Ooh does this model have a ureurea system in it? An addtive to clean the catalytic system which needs to be service once a year...
Dec 11, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
My volvo 850 transmition cut out on me. For a while the arrow on the dash was blinking and it would switch to limp mode. I brought it in to be looked at and they didn't find a problem. Last time it...
Any time the transmission goes into the limp mode, it generates an error code that tells what caused it to go into limp mode. It could be something as simple as a loose connection on a sensor for the transmission computer. The code would explain which sensor was sending the correct signal.
By restarting the car you are resetting the transmission computer, clearing the limp condition.
Nov 05, 2009 | 1995 Volvo 850
EML, Check Engine, Limp Mode
What is limp mode, and it is MiL light( mal function indicator light)it is not EML. Please specify so i can help
Jul 24, 2009 | 2001 BMW Z3
I have 8000 miles on my Tucson check engine light came on at start up this morning...gas cap is tight...no problems?????
there are over 200 reasons for the check engine light to come on, the gas tank cap is just one of them, this light and the problem that turned it on are most likely covered under the federal emission warranty, contact the dealer. see trouble code list below for some of the probelems that cause a check enghine light.
P1100 Map Sensor - Malfunction
P1101 Map Sensor - Abnormal
P1102 Map Sensor - Low Input
P1103 Map Sensor - High Input
P1104 Air Flow
P1105 Air Flow - Abnormal
P1106 Air Flow - Low Input
P1107 Air Flow - High Input
P1108 Fuel Pump
P1109 Fuel Pump - Abnormal
P1110 Fuel Pump - Stuck On
P1110 ETS System - Malfunction
P1111 Fuel Pump - Electrical
P1112 Manifold Differential Pressure Sensor
P1112 VGT Actuator - Malfunction
P1113 Manifold Differential Pressure Sensor - Abnormal
P1114 Manifold Differential Pressure Sensor - Low
P1115 Coolant Temperature Input - Abnormal
P1116 Boost Pressure Sensor - Malfunction
P1118 ETS Motor - Malfunction
P1119 Inlet Metering Valve Control
P1120 Electric Governor - Malfunction
P1120 Inlet Metering Valve Malfunction
P1121 APS PWM Output Circuit Malfunction
P1121 Throttle Position Input - Abnormal
P1122 Boost Pressure Control Valve
P1123 Fuel System Rich - Idle
P1123 Timer Position Sensor - Malfunction
P1124 Fuel System Lean - Idle
P1125 Fuel Press Sensor1
P1126 Fuel Press Sensor2
P1127 Fuel System Rich - Part Load
P1127 Control Sleeve Position Sensor
P1128 Fuel System Lean - Part Load
P1130 Start Solenoid- Malfunction
P1131 Injection Quantity Adjust
P1134 O2s Transition Time(B1/S1)
P1135 Injection Timing Servo
P1140 Inlet Air Temperature Sensor Malfunction
P1141 Slow Duty Solenoid- Malfunction
P1145 Main Duty Solenoid- Malfunction
P1146 Idle Co Potentiometer
P1147 Accelerator Position Sensor (ETS) Circuit
P1150 Barometric Pressure Sensor Malfunction
P1151 Accelerator Position Sensor (EMS) Circuit
P1152 Accelerator Position Circuit-Low Input
P1153 Accelerator Position Circuit-High Input
P1154 O2s Transition Time(B2/S1)
P1155 Limp Home Valve- Malfunction
P1159 Variable Induction System
P1162 High Pressure Pump & Fuel Line
P1166 O2s (B1) Control Adaptation
P1166 Limit O2s Lambda Control (B1)
P1167 O2s (B2) Control Adaptation
P1167 Limit O2s Lambda Control (B2)
P1168 O2s (B1/S2) Heater Power
P1169 O2s (B2/S2) Heater Power
P1170 ECM (Barometric Pressure Sensor)
P1171 ETS Valve Stuck - Open
P1172 ETS Improper Motor Current
P1173 ETS Target Following Malfunction
P1174 ETS Valve Stuck - Close #1
P1175 ETS Valve Stuck - Close #2
P1176 ETS Motor Open/Short #1
P1177 ETS Motor Open/Short #2
P1178 ETS Motor Power - Open
P1179 ETS Position F/B-Mismatch
P1180 O2 S1 Heater Circuit- Malfunction
P1180 Fuel Pressure Regulator - Malfunction
P1181 Fuel Pressure Monitoring
P1182 O2 S2 Heater Circuit - Malfunction
P1182 Fuel Pressure Regulator - Short
P1183 Fuel Pressure Regulator - Open
P1184 O2s No Activity (B1/S2)
P1184 Fuel Pressure Regulator - Power
P1185 Fuel Position - Excessive
P1186 Fuel Pressure - Too Low
P1187 Regulator Valve - Stuck
P1188 Fuel Pressure - Leakage
P1189 Governor Deviation
P1190 Intake Throttle Actuator
P1191 ETS Limp Home Valve On
P1192 Limp home - Target Follow Malfunction
P1193 ETS Limp Home - Low Rpm
P1194 Limp Home - TPS2 Position Malfunction
P1195 Limp Home - Target Follow Delay
P1196 ETS Limp Home - Close Stuck
P1300 Spark Timing Adjust Signal
P1300 Injector Specific Data Fault
P1300 Synchronization Error-CKP/CMP
P1301 TDC Sensor - Abnormal
P1302 TDC Sensor - Low Input
P1303 TDC Sensor - High Input
P1304 Phase Sensor
P1305 Phase Sensor - Abnormal
P1306 Phase Sensor - Low Input
P1307 Phase Sensor - High Input
P1307 Accelerator Sensor - Range/Performance
P1308 Ignition Coil.1
P1308 Accelerator Sensor - Low
P1308 Accelerator Sensor Circuit - Low
P1309 Ignition Coil.1 - Abnormal
P1309 Accelerator Sensor - High
P1309 Accelerator Sensor Circuit - High
P1310 Ignition Coil.1 - Low Output
P1310 Injection Control Circuit Fault
P1311 Ignition Coil.1 - High Output
P1312 Ignition Coil.2
P1313 Ignition Coil.2 - Abnormal
P1314 Ignition Coil.2 - Low Output
P1315 Ignition Coil.2 - High Output
P1316 Ignition Coil.3
P1317 Ignition Coil.3 - Abnormal
P1318 Ignition Coil.3 - Low Output
P1319 Ignition Coil.3 - High Output
P1320 Ignition Coil.4
P1321 Ignition Coil.4 - Abnormal
P1321 Glow Indicator Lamp - Short
P1322 Ignition Coil.4 - Low Output
P1322 Glow Indicator Lamp - Open
P1323 Ignition Coil.4 - High Output
P1324 Glow Relay - Malfunction
P1325 Glow Relay - Abnormal
P1325 Glow Relay
P1326 Glow Relay - Stuck On
P1326 Glow Relay - Short
P1327 Glow Relay - Electrical
P1327 Glow Relay - Open
P1330 Spark Timing Adjust Signal
P1331 #1 MF Signal Line Short
P1332 #2 MF Signal Line Short
P1333 #3 MF Signal Line Short
P1334 #4 MF Signal Line Short
P1335 #5 MF Signal Line Short
P1336 #6 MF Signal Line Short
P1337 #7 MF Signal Line Short
P1338 #8 MF Signal Line Short
P1340 IFS 2 Open
Jun 16, 2009 | 2006 Hyundai Tucson
1996 dodge avenger when cold, the transmission go in limp mode
Is the vehicle's Check Engine Light on? It should briefly light up when you turn the key on (before you start the engine) to show that the light is working correctly. Based on what I've read I believe you should have one or more trouble codes. A place like AutoZone will read the trouble codes for you for free, and you can look them up here - http://www.engine-light-help.com/generic-check-engine-light-codes.html
Dec 12, 2008 | 1998 Dodge Avenger
aFe 2004 BMW 6-Series - 645i, 4.4L V8 - Silver Bullet Throttle Body Spacers Logo
473 people viewed this question
Top aFe Renewable Energy Experts
Marco De La Fuente...
Brian Lee
Kelly C
Kelly C
Level 1 Expert
Are you an aFe Renewable Energy Expert? Answer questions, earn points and help others
