Question about Porter Cable Saws
Spring blade holder is loose
The blade holder does not work
Where can I get a blade holder for a 52" fan?
  1. Fan Blade Holder - beso.com‎
    Adfans.beso.com/‎Electronics
  2. Health & Beauty Supplies
  3. Collections
  4. Brands & Stores
Search Results
    Ceiling Fan Blade Holders ' eBay
    www.ebay.com/bhp/ceiling-fan-blade-holders
    eBayThis is a ceiling fan blade arm (blade holder) from a Casablanca Ceiling Fan Company Airflow La Verne 52" ceiling fan model 1050-9. It is in good, working ...
    Fan Blades & Arms - Home Depot
Dec 29, 2015 | Dryers
Why wont lid on my phillips senseo hd7863 close when the pod is in the holder ?
Maybe you inserted the pod with the wrong side up or you used a 2-cup pod in a single cup holder. If the clamping spring isn't working (the lid feels loose when you try to close it), that spring (that is nothing more than a straight piece of metal wire) needs to be replaced.
Jun 07, 2014 | Philips Senseo HD-7810 Coffee Maker
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
Where do I buy a rear wiper blade refill for a 06 suzuki forenza ?
Most wipers are replaced with the entire blade and holder assembly, and many no longer facilitate blade itself replacement. It is worth it, as the arm and spring wear, over time.
The entire blade and holder easily separate from the arm and the new one clicks right in.
Mar 26, 2011 | 2006 Suzuki Forenza
We own a Dewalt DW735 13" planer. Have lost or misplaced the owner's manual. We need to reverse the knives for the first time, and do not know how to do it.
Unplug the machine then crank open the head up as far as it will go. Underneath, in the middle of the head you'll find two feed rollers and a cutter head with the blades on it. Even dull the blades are very sharp so work carefully. Each blade is held in place by a blade holder and eight allen screws. Remove all eight allen screws and the holder and blade will fall out. If they have excessive sawdust or tree goo on them they may need a bump from the plastic end of a screw driver to knock them loose. Keep track of how they come off so you can put them back on the same way only with the blade turned around. The top of the blade holder will fit into a channel in the blade so they'll all go back in lined up correctly. Turn the cutter head carefully to get at the other blade(s) to change them.
Nov 15, 2010 | Garden
Where do you put the two little springs, and what do they do? My blades have started to rattle on clipper. Oster turbo clippers.
The springs probably go with the carbon brushes, to hold them in. To find the brushes, use a dime to unscrew the two circles on the side of the clippers.
The rattling could be from loose screws on the blade hinge. My turbo clippers did the same thing. The blades rattle if the screws are even slightly loose.
Nov 12, 2008 | Oster 76076-010 Hair Trimmer
Paper will not feed, some large spring is loose and don't know where it goes
Okay, I figured it out - if you unhinge the paper tray holder and you look at the bottom of it there is a little circular indentation that is where one part of the spring goes. I surperglued it that. Then if you look inside the paper holder you will see another circular type indent that has a tiny little plastic latch at the top of it - it will match up with the one on the paper try holder. I put the superglued spring into the printer and shoved it down with the handle of a comb and a long kitchen knife.
Hope that helps!
Oct 01, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Cleaning grinding blades
mazzers have 3 springs in grinder body, each one support for upper burr holder. check for them , if it is not the case than consider that the spring could come with coffee. often we see stones and metal parts geting between burrs.
clean it again and look good for 3 springs , if they are in their place, close the burrs to finest than go back for half of circle and grind coffee.
Mar 25, 2008 | Mazzer Grinder-doser MINI MOD. B Electric
Saws Logo
44 people viewed this question
Top Porter Cable Saws Experts
Dave
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
