Question about Haier Top Load Agitator Encore Washer
Washer not spinning
Please help
GE washer wle4000b1ww won't spin with clothes in it but will spin when empty.also the spin light blinks,I have checked the belt and the belt is good please help mother of 2 thank u
Normally, when a washer will spin without cloths, the washer is doing all the basics correctly. But when you add cloths, which means adding weight, the washer will not, then its a suspension rods issue. The suspension rods absorb the weight and allow the washer to spin.
May 25, 2016 | GE Washing Machines
Washer won't spin or agitate
what brand? model name and number would help. it might just need reset. or could be other problem.
Jan 26, 2014 | Washing Machines
My washer wont spin, it washes but then it wont start the spin cycle.....please help
what is the model number and the brand name?most likely you have a bad lid switch.it's a saftey on most washers,the factory doesn't want the washer to run when it's in spin so if you were to open the lid while it was spinning the washer would shut down,if the lid switch is broke it's like the lid is open and it won't spin or run
Jan 23, 2011 | Washing Machines
Washer wont spin out
If your washer is not spinning you need to check this part.
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt(belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer stopeed spinning
if machine spins while washing, transmission is good. if it does not turn at all, could be control panel .need more details
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer quit spinning
Sounds like the lid switch has failed. This switch will not allow the drum to spin if it senses that the door is not locked. Have it replaced and that should take care of the problem. Hope this helps. Good luck.
Jul 23, 2009 | Roper RTW4300SQ Top Load Washer
Washer won't spin
Hi, If the washer agitates but does not spin, it could be a lid switch. When the timer is in the spin cycle, can you hear the motor running?
If you look around the lid opening, you should see the model# label.
Most common problem is the lid switch and that is worth fixing. Please let me know if this helps and if I can assist you further.
Vic
Jun 28, 2009 | Kenmore 24032\24036 Top Load Washer
The washer will not spin
my washer will not finish spin and reins cycles please HELP ME
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't spin in final spin out
Hello harley1964dm
Welcome
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Huuum
Please remember to leave a rating
Oct 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Haier Top Load Agitator Encore Washer Logo
    Top Haier Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Owen Barnes
    Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
